My 71 camaro LS2 w/ MAG build
Old 08-21-2010, 03:53 PM
edge04's Avatar
Default My 71 camaro LS2 w/ MAG build
So last year I spun a crank bearing and it is winding up costing me $15k
LS2 5 over, srp coated pistons, coated bearings, forged manley rods, trick flow 235 w/ 650 springs and Yella 1.7 rockers, blower cam, TVS 2300 over driven rears, holley 90mm TB, modified injectors flowed matched, 1 7/8 long tube dynatech. Motor assembled by AES and fuel rails and system from Nasty Performance. Snow Meth kit
test fitting the maggy
hood closes!
twin disk McLeod clutch!!
didn't want to modified the tank so went with external pump
Old 08-21-2010, 03:54 PM
edge04's Avatar
sorry, dont know how to make pics smaller
Old 08-21-2010, 04:15 PM
LS1 SPEED's Avatar
nice build and awesome looking car
that thing should fly once finished up
Old 08-21-2010, 04:56 PM
TurboAv's Avatar
Awesome! I never should have sold my split bumper.
Old 08-21-2010, 07:44 PM
BLK02WS6's Avatar
Damn - that is sweet!
Old 08-21-2010, 11:16 PM
nuckifuts's Avatar
Beautiful car. I love 70-73 camaros and firebirds.
Old 08-21-2010, 11:54 PM
MYSTIC-1SC's Avatar
nice looking build
Old 08-23-2010, 10:49 AM
Nasty N8's Avatar
Nice car sure will be fun when its done.
Old 08-23-2010, 11:21 AM
Rickys S/C Z28's Avatar
wow man that bad ***
Old 08-23-2010, 11:39 AM
edge04's Avatar
thanks guys! hope to have it fired up this week, will post more pics this week as well.
Old 08-23-2010, 11:51 AM
Klimaxx's Avatar
my 2300 wont be bolted on for a few weeks... get me a vid of it running! I want to hear how much it whines.. can you post a pic of blower to firewall clearance?
Car looks great, nice suspension bits from what i see too..
Old 08-23-2010, 12:22 PM
edge04's Avatar
will post video after start up. might be quiet as i don't have the rear cogs. i wanted to check firewall clearance first. looks like they will fit. car has
Global West Tubular Control Arms – Upper and Lower
QA1 Adjustable Coil Over Front Shocks
Del-Alum Front Suspension Bushings
Hotchkis Sway Bars Front and Rear
Flaming River Power Box with Quick Ratio Gears
Flaming River Stainless Steel Tilt Column
Flaming River “Waterfall” steering wheel
Detroit Speed Composite Halogen Headlamps
18 Circuit Painless Performance Wiring Harness
ATCo Racing Custom Polished Alum Radiator.
SPAL dual 12” elec fans 3100cfm
New Moser 12 Bolt
Detroit Locker Limited Slip Diff
Richmond 3:55 gears
Stainless Brakes SSBC 4 wheel Disc
Detroit Speed 3” Rear Drop Leafs
Old 08-23-2010, 12:28 PM
Klimaxx's Avatar
PERFECT! I have the underdriven 10 rib at the moment (its on a stock longblock) and I thik my firewall in my 67 camaro will be similar to yours, what motor mounts did you use?
Old 08-23-2010, 12:33 PM
edge04's Avatar
^^street and performance made to set the engine back about 2 inches so you should be fine!
Old 08-24-2010, 06:03 PM
edge04's Avatar
plenty of room even with my fuse there
Nasty fuel rails. The pic does them no justice.
poer steering, alternator in place and line ran for the meth injection
Old 08-24-2010, 06:58 PM
Klimaxx's Avatar
What kit is that(application)? i need to get the throttle cable mount like you have to use my cruise the one that came with my 04 gto kit looks nothing like that and I'm not sure where it mounts.. also did you fab up that mount for the lokar (i have that same cable in mine)
thanks for the firewall pic!
Old 08-24-2010, 07:07 PM
edge04's Avatar
yeah mine is a GTO kit too and that is a lokar cable but as you know the stock cable mounting bracket will not work (at least not with the holley tb). I just made the bracket today that the cable is bolted too and then it is bolted to the SC. You can still see the stock bracket to the left (which is staying because I would need to move the shaft). The one made is lined up perfect with the TB. You can hardly see the new bracket but I think I still may get it polished. Or I add drive by wire???
I also don't like the meth solonoid zip tied to the tank bracket so I am going to mount it bewtween the pump and tank.
Old 08-24-2010, 07:19 PM
Klimaxx's Avatar
so its an 04 gto kit?
Old 08-24-2010, 07:32 PM
edge04's Avatar
nope 05-06 LS2
Old 08-24-2010, 07:34 PM
MillsMotorvation's Avatar
Love it!
Quick Reply: My 71 camaro LS2 w/ MAG build
