Explain blower cam Vs. Non-blower cam
Old 09-20-2010, 09:29 AM
robertbartsch's Avatar
Default Explain blower cam Vs. Non-blower cam
What is the difference between a cam for a supercharged blower car Vs a cam for a naturally asperated car?
Thx...
Old 09-20-2010, 11:11 AM
TurboAv's Avatar
Overlap. NA cams have more.
Old 09-20-2010, 12:37 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
Assuming there is point where you can't keep increasing intake duration to stay below a given max rpm, wouldn't you run as much or more exhaust duration, hence a big split, to get that exhaust charge out?
Old 09-20-2010, 01:48 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Higher numbers on the lift and duration on the exhaust side is typical of blower cams. The air is being forced in, so the intake side is not as critical, but the exhaust side of things needs all the help it can get to expel the spent gasses.
Old 09-20-2010, 05:45 PM
joeys99z28ss's Avatar
good to know
Quick Reply: Explain blower cam Vs. Non-blower cam
