Dual Caliper Setup
Old 10-01-2010, 11:20 PM
1998TA__1991RS's Avatar
Default Dual Caliper Setup
Is anyone using these on turbo cars? which kit are you using?
Old 10-02-2010, 05:19 PM
Fireball's Avatar
yup...wilwoods. but I think think they make the kit for GM housing ends...I use the ford ends on my 9" rear.
Old 10-03-2010, 12:06 AM
the car has a 9" in it now, but i dont know if its a big or small bearing
Old 10-03-2010, 12:35 AM
bigsticksupra's Avatar
late big
Old 10-03-2010, 05:58 AM
Fireball's Avatar
not talking about bearing...talking about housing ends...the GM ends use the ford bearing but I run a "Big Ford" end that uses ford brakes. They will not accept a GM caliper.
for your setup I believe you can only go strange or aerospace...
Old 10-03-2010, 09:05 AM
WS6HUMMER's Avatar
I have a friend with a Strange setup on his car, it works awesome!
Old 10-04-2010, 12:06 AM
how much boost are you guys typically seeing on the footbrake with the dual calipers? I know each setup is completely different, just trying to get a general idea
Old 10-04-2010, 04:52 AM
Fireball's Avatar
I was seeing 4-6
Old 10-04-2010, 11:31 AM
I was seeing 4-6
good, thats exactly what i need, thanks
Old 10-04-2010, 11:36 AM
cracker's Avatar
Aerospace
Old 10-04-2010, 02:43 PM
dacajun's Avatar
Mark Williams
Old 10-05-2010, 11:32 AM
LS1TECH Sponsor
Steve Burger's Avatar
We have done both Aerospace and Strange. The Strange setup is a pain to bleed. One caliper sits on top of the rotor and is not in a place that is easy to get the air out. The Aerospace setup has the calipers at 9 and 3.
Both are good setups. If you want some give us a shout.
Old 10-05-2010, 11:39 AM
Need_a_Camaro's Avatar
Could this be added to the Aerospace kit I already have, or is the bracketry different?
Old 10-05-2010, 11:51 AM
LS1TECH Sponsor
It can be added.
Old 10-05-2010, 01:02 PM
Can you pm me a ballpark est? I have a Strange 12 bolt with the Aerospace kit.
Old 10-05-2010, 03:09 PM
LS1TECH Sponsor
The upgrade is 475.00 for the brackets and calipers with hardware.
