Could I turbo my LSX Block
Old Oct 3, 2010 | 10:55 PM
1fastxz's Avatar
Default Could I turbo my LSX Block
Was going N/A but could get a Turbo kit at a good price
the issue is the block is bored to a 4.185 bore already and the crank i have is a 4.10 stroke
haven't ordered the pistons yet, could get the compression down to 9:59:1 if i do a dish piston with a -23cc dish
question is
are the cylinder walls to thin to handle boost?
would like to make around 800 rwhp if i go the turbo route.
Old Oct 4, 2010 | 10:45 AM
87silverbullet's Avatar
Yes you could turbo it but I wouldn't use a 4.100 stroke crank due to the compression height of the piston and it has not been recommended lately to use a 4.1 stroke crank. I really don't like the 4.185 bore too much either but it is still not bad to use. I would sell the crank and get a 4.00 crank and make it a 440 and turbo that.
Old Oct 4, 2010 | 12:42 PM
1fastxz's Avatar
Ok I was thinking the same thing with the stroke
I got the block used so couldn't do anything about the bore
Just found a kit at a good price and thought it like to make a little more power then just keeping N/A
It's a street car, not going to try to max out the car with power
But think it would be fun with 800-900 hp and tq
Old Oct 4, 2010 | 01:09 PM
Is it a t4 or t6 flange kit? With that many cubes you are going to need a pretty decent exhaust housing and there a are very few big turbos on a t4 flange.
Old Oct 4, 2010 | 03:09 PM
1fastxz's Avatar
Think it's a T4 flange kit
Old Oct 4, 2010 | 03:32 PM
The biggest t4 that is out I can think of is a 91mm I think mightymouse put a thread on here on it. Can't remember the sizes of the exhaust housings available. Give Jose' at Forced Inductions a call or Rob at Modular Turbo a call they can recommend a turbo to keep the back pressure down with a big cube motor like you are building. 800-900 won't be a problem though with those cubes and that big of a turbo.
Old Oct 4, 2010 | 03:39 PM
XtremeDime's Avatar
With a 440+ youre going to need a huge *** turbo!
Old Oct 4, 2010 | 06:28 PM
venom ws7's Avatar
You need T6 with those CI and minimum 88 if your only looking for 800rwhp or you can go with twin 70+mm
Old Oct 4, 2010 | 06:47 PM
1fastxz's Avatar
Looking like it will be a rear mount turbo kit. Thinking maybe something in the 88-91mm will be what im looking for.
There is a good amount of room in the back of the GTO.
So will have to do some measuring this week under the back in to see what im working with.
Old Oct 4, 2010 | 07:27 PM
ryarbrough's Avatar
A T4 91mm on a 440, no matter how you cut it, would seem like it would be problematic. I'd imagine backpressure would be unbelieveable
Old Oct 4, 2010 | 08:12 PM
1fastxz's Avatar
Even located at the rear of the Vehicle?
the dump pipe would be less then 2 feet from the end of the turbo?
Old Oct 4, 2010 | 08:16 PM
ryarbrough's Avatar
IDK. It still seems like an awful small turbo for the ci.
Old Oct 4, 2010 | 10:29 PM
1fastxz's Avatar
but with a turbo like a 91mm how would lag be?
dont want to be waiting till 4000rpm befor it starts makeing power
need to find something that will have good maners
this is a street car not a track only car
Old Oct 5, 2010 | 10:53 AM
Its the pressure from between the motor and the turbo, not after the turbo.
Lag wouldn't be bad since an 88 or 91 are your choices and you would end up dealing with an on the smaller side exhaust housing for that big of a cube motor. Cam choice would play a role in this too.
You might want to see if you can cut the t4 flange off and put a t6 on or get an adapter. My choice would be the first one. Then you can go with something a lil bit bigger to suit your engine and give you good spool with good top end power.
Old Oct 5, 2010 | 02:41 PM
1fastxz's Avatar
with the rear mount kit i dont think it would be to hard to change the flange
so ill look into that
what turbo would you recommend?
Old Oct 5, 2010 | 02:46 PM
JBarron's Avatar
If you want responsiveness on the street, a front mount turbo(s) would be better. Is there not enough room? I mean, rear mount cars can be very fast, but you're always leaving a little on the table, compared to a front mount.
Old Oct 5, 2010 | 03:26 PM
venom ws7's Avatar
What transmission are you running??
T6 91mm 454ci will work great even rearmount with the right cam and compresstion I'm sure you can get full boost under 3500rpm..
Here is T6 88mm on Little 383ci with M6 ZO6 I Remember Josh saying the car got full boost at 4000rpm on the street and made sick numbers
http://www.youtube.com/watch?v=RorIX...ext=1&index=44
Old Oct 5, 2010 | 04:10 PM
1fastxz's Avatar
i have a A4 that im running
