Will this cam work on my setup, help!
I have a pat g custom spec cam and my tuner says the cam isn't big enough and the motor isn't gettin enough air. The far is 11.80s across the board
The size of the cam is a 226/230 .598"/.600 114lsa +1 eps lobe.....
The car is a iron 346 with a front mount pt88
Pls help
Pls help
that cam wont make that pt88 shine, but it also is only a 346.
how much boost anr u runnin????
what type of filter on the turbo?
inter cooler setup???
give us some details on the induction
Restricted User
Pls help
Pls help
I'm happy with what I can get, but I'm expecting over 750rwhp easily. It just doesn't make since to me the tuner said there's some sort of restriction, the kpa was reading way low. he thinks the heads/cam combo but I've seen ppl push stock 317 heads over 900 I called Josh @ ky turbo he said it has to be in the tune. So will someone lknowledgable tell me if this cam will work efficiently over 700.... Or do I need to swap it.
Sorry for the shitty grammar I'm trying to type on this ****** iPad
So you know very little about the build, very little about the problem...and you think people can help based on that info ?
Might be worth taking it to a better tuner maybe ? Who can diagnose the problem properly, if indeed there is one.
what more info do you simply need. its a simple quesiton WILL THIS CAM WORK FOR THIS SETUP? . YES it was a dyno jet. What should the timing be at on the average car under 16lbs of boost?
