How Much RWHP/TQ LS7 Supercharged???
Old 11-07-2010, 02:37 PM
rockojugs's Avatar
Default How Much RWHP/TQ LS7 Supercharged???
Any guess on much rwhp/tq with LS7 (forged internals) ATI supercharged engine (93 octane) one should expect to see. Long tube headers, cam built for supercharger, fuel system upgrade, and 8.8:1 compression on 8 to 10 pounds of boost.
Just looking for ballpark numbers.
Old 11-07-2010, 04:06 PM
blue00ZZleeper's Avatar
Thats a little low for compression on a S/C motor. What blower is it? Cam specs? We need more on the combo then that.
Old 11-07-2010, 06:24 PM
rockojugs's Avatar
I initially thought it would be 9.5:1, but Pro Line Race Engines is recommending 8.8:1 based on heads and cam.
ATI Procharger D-1SC 8 to 10 pounds of boost
AFR 225 Heads 72CC Springs & Retainers
Custom Cam 234/240 598/609 114LS BLWR Specs
Old 11-08-2010, 12:16 AM
STAR's Avatar
If your only going to be seeing 8-10 lbs of boost you should raise your static compression to 10.1-10.5 I don't understand why you need to lower the compression based on the heads and cam
Old 11-09-2010, 12:26 AM
fatmat80's Avatar
Dont understand why compression needs to be that low either but you should see 700+ rwhp with that setup good luck.
Old 11-09-2010, 12:47 AM
9.5-1 is perfect. Dont go lower. Blower cars get a little doggy out of boost with low compression. 700 should be pretty easy on 10psi. I would try to upgrade the blower to a F-Series though. You'll tap a D1 out pretty quick on that combo.
Old 11-09-2010, 05:48 AM
venom ws7's Avatar
What trans and rear??
I agree with blue00zzleeper low comp and low boost with blower is not a good setup...
630-670rwhp is my guess and low mid 500rwtq ..
Old 11-09-2010, 08:56 PM
BigRich954RR's Avatar
at least 9.5 on that motor i did 15 psi on a 11.1 ls 427 with pump gas93 and meth
Old 11-09-2010, 09:25 PM
jashell1562's Avatar
Keep the compression Low and change the head unit out to a F1C and turn up the boost to like 21 or 22 pounds and you will make some killer numbers on pump gas , I would say 825 to 900 range. You will like it, my little 6.0 with an F1A Made 775 on 18psi , I need to dyno it again on 21 pounds..
Old 11-10-2010, 10:01 AM
Unreal's Avatar
Stock ls7s are making 650rwhp on 7-8psi.
Quick Reply: How Much RWHP/TQ LS7 Supercharged???
