for those of you who have done turbo 5.3 swaps into your fbody
got a couple of questions...my LS1 is about to the point I can drop it out of my car. I'm trying to get a list of parts I'll need to support the 5.3L in place of the LS1 in my 2002 Camaro (5.7L fbody parts that are incompatible with the 5.3L). I'm reusing the LS6 intake manifold, fuel rails, and throttle body. So far I know I'll need a new oil pan (or swap the one off the LS1 I plan to sell). Will the rest of my accessory drive system swap right over to the 5.3 (PS & water pump, alternator [relocated], etc)? How about the wiring harness/PCM from the LS1? Motor mounts all the same? I guess I'm not sure how similar the 5.3's are compared to the 5.7's.
Also, I'm planning to bolt on the truck manifolds + hot side prior to installing the 5.3 back in the car - no problems doing that, is there? I figure it'll be easier to do before hand.
Fbody LS1 blocks use 3 bolts to hole the alt on the front of the engine and one on the side
With the truck block, one hole is present, one boss is present and one boss is completely missing up front. Side bolt is present. Not drilling/tapping the hole up front leaves a single bolt holding the alt aligned up front and one small bolt on the side. Not worth it IMHO
But, most turbo setups relocate the alt, so you very well could just skip that whole ordeal
FWIW, iron blocks only have 4 motor mount holes where alum blocks have 6. The two rear holes on alum blocks arent used on any setup Ive seen, so it's no consequence
