Sale or build turbo kit?
Thinking of trading my car for a GTO, but at the same time I want to build a turbo kit over time. Which way to go with mods listed below and what kind of kit should I do. This will be my first FI car and the more specific on whether to do front mount or rear mount and reasons why would be great as well as sizes for a turbo and intercoolor etc....New to the whole subject as of right now. Current mods listed below...
Thinking of buying all the pipe for a rear mount that I need and cutting it and doing a semi-mock up with tape holding it together then having an exhaust shop weld it for me.
Which setup will be less of a headache for a first timer?
Goal is around 500hp!
99' Z with 115,xxx miles
Performance/Drivetrain:
-Patriot stage ll 5.3 heads (done @ 108k)
-Comp custom grind cam (done @ 103k)
-Ls6 intake
-FIPK ll filter with smooth bellow
-45# injectors
-Comp 918 valve springs
-Ported ls6 oil pump
-7.350 pushrods
-Ls7 lifters
-Ls2 timing chain
-4:10 gears
-Monster Stage 2 clutch (done @ 113k)
-Tick adjustable master cylinder
-GM slave
Exhaust:
-Pacesetter LT's
-ORY y pipe
-sweet thunder muffler
-SLP 3" tips
-Ls6 intake
-45# injectors
-7.350 pushrods
-Ls7 lifters
-Ls2 timing chain
-4:10 gears
-GM slave
Exhaust:
-Pacesetter LT's
-ORY y pipe
-SLP 3" tips
Thinking about swapping to the 317 heads because of the compression of my heads with a 59cc. And possibly dropping down to a ls6 cam. Would like to be sitting right on 500hp with the turbo since it's stock bottom with 115K
Restricted User
I had a GTO and quickly realized that making it fast was an uphill battle. First problem is the weight. Second problem is the entire drivetrain behind the transmission. Then there are the issues with the struts eating up the tires, the electrical gremlins and the glue that holds the liners to the interior falling apart. My 2004 GTO was a big pile of **** by 2007 when I turned in the keys on the lease.....with a smile.
Still haven't got any suggestions on whether to do front or rear mount. Great thing about rear mount is not having to deal with the relocation of stuff. Any thing that has to be relocated up front besides the alternator?
