PT88 turbo LS6 wont pull past 5k, w/dyno graph
Old 07-17-2011, 11:49 PM
  #121
jeffreycastgsx's Avatar
Always be sure to check for "boost leaks", symptoms sound very similiar to one.
Old 08-07-2011, 08:58 PM
  #122
ablakez28's Avatar
Bump because I had the same issue today
Old 08-22-2011, 05:45 PM
  #123
z28adiction's Avatar
And you found out you were running the wrong scaling for the MAP sensor. You thought it was a 3 bar but was in fact a 2.5 bar. Re-scaled and 800rwhp/830ft lbs of tq.
Old 08-22-2011, 05:58 PM
  #124
ablakez28's Avatar
Yes.
Old 07-05-2013, 08:26 PM
  #125
black-sinner's Avatar
Oh dude, come on... Dyno the thing already 😁
Old 07-05-2013, 09:01 PM
  #126
A_Pinstriper's Avatar
LMAO, two years later......
Old 07-05-2013, 09:04 PM
  #127
autoaddictions's Avatar
Funny I'm having the same issue. I've thrown all kinds of parts and plugs at it. I'm dumbfounded.
Old 07-06-2013, 09:18 AM
  #128
Eagle02's Avatar
Two years later and it's actually fixed. Took the heads in and had the spring pressures measured. Needed to have the springs shimmed ... Now is pulls fine on the dyno. HP and TQ track linearly until TQ passes HP around 5500. The car is running better than ever!
Quick Reply: PT88 turbo LS6 wont pull past 5k, w/dyno graph
