Best turbo size for lt1
I am gonna do a rear mount turbo setup on my stock 94 z28. Im aware stock internals are weak and will eventually fail but I wanna run 7 psi and see how long she lasts. Any knowledge or suggestions would be much appreciated, thanks!
A MPT70 will spool QUICK on an LT1. I would go larger a T76 with a P trim would be a great choice and give you growth for when you build motor
Good luck
Edit
1) and use a T4 flange so you have more choices T3 has fewer choices.
2) Q trim
Talk to Modular Turbo.
I WOULD go with MPT 76 with Q trim I typo'd in last post
http://modularturbo.com/storefront/p...products_id/33
BUT Rob will likely recommend smaller...if you stay SMALL a 70 is better but most of us go bigger and rearmount would love a Q trim....
