New forged 347 with sinngle 76mm smoking on decel :(
So I got a new forged 347, that is broken in now, and im having a bit of a oil burning issue. I bought a used t76 turbonetics journal bearing turbo that I am running. I have a -4an feed and a -10an return to the oil pan. The car when in neutral can be reved to the moon and it will NOT smoke. I can drive it around all day and hit a little boost and it will NOT smoke, but when I lay into it and hold through 3 and 4th full throttle and reach max boost, when I let off the gas, I get clouds and clouds of oil smoke. So Its clearly related to higher boost for some reason. Now this being a new engine, I would think everything should be all good. Even my heads were all worked over. I DO have the revExtreme dual valve catch can setup, and I have removed all the lined to the catch can and the lines going to intake etc, and found no signs of oil in those lines. So it being a pcv issue seems to be un likely.
Any ideas ? Is this simply my turbo? I am hitting about 11 psi max boost, and thats usually when it smokes
Well, The turbo is mounted in the front of the car where a centri supercharger would go. Its hinson supercars turbo kit.... I have checked all my pcv fittings, and found NO oil residue anywhere. I even pulled the charge pipe off the turbo and it looks clean of oil as well.
well the way it sits the feed is on top and the drain is on bottom. so its fine. But I will say that my drain line right off the turbo goes straight down but then it makes a 90 left and down to the oil pan hmmmm
I don't see that causing the problem, hopefully tomorrow some of the sponsors will be on and can help you out.
What I can remember about turbo clocking is that the discharge volute has to be at in a certain posistion relative to what posistion the turbo is mounted to allow adequate drainage. Even if the drains and feed are in the right places if the oil just pools in one spot and never has the chance to drain then you will see what is happening now, and that's the turbine housing is heating up so hot that it's finally burning that oil that has pooled in that spot off. This is why you don't see it on light throttle or under normal driving.
Somone correct any of this if it doesn't sound right, but I think that's pretty accurate.
and the car doesnt smoke under load. Its after a wot run that I let off the gas and it smokes like a bug killer. If I apply the gas again when its smoking, the smoke immediately stops...
Would having the drain clocked at a slight angle back to the engine be better? This is how I have mine... I figured when you're on it the front end rises a little and then the acceleration force, having it at an angle would be the least resistant path. Its at about the 4:30-5 o clock position.
It definately sounds turbo related and not engine related.
yeah my return line is at a funny angle. Idk if I said it earlier but right off the turbo it goes straight down, but then it makes sort of a 90 degree turn to the left and down into the pan... Idk if that could be the issue. Makes me want to make it a more direct straight shot down into the pan.
