S480 vs 7675 pte
Old 02-14-2012, 05:05 PM
Transam Rocket's Avatar
Default S480 vs 7675 pte
Will the s480 t6 1.10 ar come close to a pte 7675 turbo in power wise I know pte will spool faster? Looking for close to 700rwhp or high 9s on my 5.3 with victor jr manifold tu1 cam meth injection and e85.. 02 camaro 4l80e 8.8 rearend The pte 7675 is just our of my budget
Old 02-15-2012, 10:39 AM
LS1TECH Sponsor
DrTurbo's Avatar
A 480 will make more power.
Old 02-15-2012, 10:51 AM
S480 with the 83mm 1.10ar right? How would that turbo spool on my 5.3 or do you think theres a better s400 for my goal
Old 02-15-2012, 01:55 PM
turbocamaro125's Avatar
s480 will make alot more then 700hp....but you should have no problem spooling the 480 with the 83mm wheel
I had a stock ls1 with a blower cam and 6sp and s480 1.32 96mm wheel and it was not to bad made 1lb at 3600rpm and 10lbs at 4000....power came in hard....the auto will help you soooo much
Old 02-15-2012, 03:30 PM
831jd's Avatar
Nice....
Old 02-15-2012, 04:01 PM
Thanks just what I wanted too know... What stall to launch this bad boy hard
Old 02-17-2012, 10:16 AM
831jd's Avatar
3600 stall?
Old 02-17-2012, 02:04 PM
Sarg's Avatar
Going with the larger 96mm and doing a 4000 on mine. Looks like we may have a good number of 5.3 s480s with various turbines coming soon.
Old 02-17-2012, 04:10 PM
831jd's Avatar
Are you doing any rod bolts and rod bearings? Im also doing the same turbo but the 83mm what stall size would be best?
Old 02-17-2012, 05:45 PM
Sarg's Avatar
ARP rod bolts and head studs. I relied on the experience of Circle D converters to come up with my stall speed. They determined that a converter that flashed to 4000 rpms would be best. Hoping that is the case! If not I can always have them adjust it. Best I can tell, you will probably be within 500 rpms of me on spool up, but it really depends on exactly what your purpose for the build is. Mine is more drag race than street.
Old 02-17-2012, 06:10 PM
831jd's Avatar
Cool
Its more a drag car and few weekend street pulls at the local car meets
Old 02-17-2012, 08:51 PM
Shanna's Avatar
for five hundred buck you can make both spool way faster go to the supra store and look at there quick spool setup
Quick Reply: S480 vs 7675 pte
