obx vband clamps any good?
Old 02-22-2012, 11:18 AM
jks67ss396's Avatar
Default obx vband clamps any good?
guys
i need some 2.25" vband clamps. ive seen a few people say obx vband quality is pretty decent.
if i really have to pony up the 80 bucks x2 then i will, but those obx's are a lot less
race parts solutions dont have 2.25...
thanks
jeff
Old 02-22-2012, 11:36 AM
GulfM3's Avatar
What part of your turbo setup will the clamps be used.
I've used the cheap ones on my exhaust, and they work fine, but I wouldn't use them for a joint that will be under pressure (any coupling pre turbo).
I don't have any experience with V bands for intercooler pipe coupling.
Old 02-22-2012, 12:02 PM
pwrtrip75's Avatar
They will advertise they are 100% stainless including the flanges... The flanges are not.
WTF?.... They really make ones for $80. ?? Wow.. what kind of precious metal are they?
Old 02-22-2012, 12:09 PM
jks67ss396's Avatar
ill be using these on the truck manifolds and pre-turbo piping
i think i want the stainless.. read somewhere stainless matches the "cast iron" of the truck manifolds better
keep the ideas coming
thanks
Old 02-22-2012, 12:57 PM
123quattro's Avatar
Pretty much everything they sell is junk.
Old 02-22-2012, 01:52 PM
killernoodle's Avatar
Not necessarily. I've had good luck with ebay brands of stainless VBands. If you want it to seal and positively locate against the other one, just make the pipe inside the vband stick out from the end of the face of the flange and recess the pipe in the other one. That way one is essentially male and the other is essentially female. Much better seal that way.
Old 02-22-2012, 02:03 PM
tim99ws6's Avatar
LOL at that statement. I assume you have overpaid for something and now are jealous of those that have had good results with OBX
I have used the OBX v-bands and had good success with them on my manifold turbo setup. They worked great. Only issue i had was the t-bolt and nut giving up after multiple uses or torqueing down on them. I just replace that and am on my way.
Old 02-22-2012, 02:09 PM
TTLS1GP's Avatar
Use them for pre and post turbo applications in various sizes from 2" all the way up to 3.5"
No issues.
Old 02-22-2012, 02:34 PM
jks67ss396's Avatar
good to hear guys
thanks!
Old 02-22-2012, 03:23 PM
JAX04's Avatar
As i said in the PM, the OBX Vbands that i bought with the alignment ring inside were twice the quality of any vband ive used before, thick flanges for the clamps, and thick extensions to weld too, means less prone to warping during welding.
I think i gave like 25 bucks a piece or something for them and would buy them again in a heart beat.
Old 02-22-2012, 03:32 PM
dville_gt's Avatar
I used them on my hot side and like JAX04 said, they were real nice, the alignment ring fit perfect and they welded great. I used the 2.5" and got them on ebay
Old 02-22-2012, 05:00 PM
LS1NOVA's Avatar
Plan on using them soon. Got to have the alignment ring, without it its a pain.
Old 02-22-2012, 08:40 PM
ACCLR8N's Avatar
Cast irons have a lower rate of thermal expansion. Stainless steels (304) have a 30% higher rate of thermal expansion than mild steel. I'm building my manifold with mild steel flanges.
Using the OBX flanges as well. Only mild steel I found in 2.25". Mine came with the male/female alignment feature. Fit tightly together.
Old 02-22-2012, 10:43 PM
a4ls2goat's Avatar
im using 2 obx vbands on my turbo kit.. working perfect
Old 02-22-2012, 11:04 PM
No need, just assemble your pipes like this:
Old 02-23-2012, 05:58 AM
JAX04's Avatar
I like this, it accomplishes two things in my eyes.
1. alignment
2. strength for when your hanging something off of it.
Old 02-23-2012, 06:36 AM
LS1NOVA's Avatar
The v bands I was using before had a step on them to locate the pipe and you couldnt push the pipe through. I definately like that though, looks like it would be much stronger.
Old 02-23-2012, 08:50 AM
madmax4499's Avatar
I welded MS OBX to my truck manifolds, over a year ago, they work great. Just dont over tighten them, I destroyed one clamp trying to use a 3/8 impact driver to tighten it. now i use a little lube and 1/4 drive ratchet. No problems.
Old 02-23-2012, 09:10 AM
You usually won't be able to push the pipe through as it sits. I always had to cut a couple slits in the pipe to shrink them, hammer them through the ring, then weld the slits up. I don't really trust a butt joint on a v band connection, I'd rather have a lap joint there and use the tube to positively locate the joint.
Old 02-23-2012, 10:36 AM
ACCLR8N's Avatar
If you are doing that, wouldn't running a 2.5" flange over your 2.25" 16ga tubing be easier?
Quick Reply: obx vband clamps any good?
