How much would I gain from 317's?
Old 03-17-2012, 10:39 PM
Ws6power1's Avatar
Question How much would I gain from 317's?
Hey guys just wandering if it will be worth it to pick up a set of stock 317's pretty cheap and do them when I'm swapping my intake manifold. It's a 98 ws6 with the 806 heads. Full bolt ons, running a 8lb pulley on a gtrim. Do you think it would be worth it now for a couple hundred or should I just wait until I have the funds to get a worked tsp set? Thanks
Old 03-18-2012, 08:30 AM
Adam86's Avatar
On 8psi I don't see the point. If you plan on cranking the boost up later, then maybe pick up a set. Also keep in mind you will need new head bolts (studs, preferably), head gaskets, coil brackets, and valve covers. Also get ready for the PITA that is cleaning the graphite head gasket off of the '98 block.
Old 03-18-2012, 02:29 PM
Ws6power1's Avatar
Ok that's what I wanted to know thanks. Ill wait and get a worked set when I upgrade to a t trim.
Old 03-18-2012, 02:49 PM
Adam86's Avatar
Do be aware that you should probably upgrade your stock head bolts anyway. Also, the graphite head gaskets on the 806s aren't nearly as good as the MLS ones and seem to blow out under boost more often from what I've seen. Have you considered going with something like a 241 head? I went with those on my '98 and plan on keeping them up through 15psi. However, that's also with 9.5:1 compression and dished pistons.
Old 03-18-2012, 05:25 PM
2000RATA's Avatar
A 241 head would be a lateral move from a performance standpoint.
Old 03-18-2012, 05:31 PM
Spade's Avatar
If you can get them cheap I do not see a problem with it. I have them on my 98 as well. Did not port them any but wanted them for a FI standpoint. I do have the ARP studs though. Those heads are still better than the 98 heads. I like the center bolt valve covers way better than the perimeter bolt ones that are on the 98's. I would say if you can get them with covers and all go for it.
Old 03-18-2012, 05:55 PM
Johnv's Avatar
I think it would be worth the cost/effort to swap to 317s,
They are better flowing and lower compression ratio making your engine more boost friendly, and the addition of ARP head studs and multi layer gaskets will add to reliability.
Old 03-18-2012, 06:23 PM
Adam86's Avatar
Yup, but I put them on so I could use MLS gaskets instead of the graphite ones. Got them for next to nothing so it made sense at the time.
Old 03-18-2012, 07:03 PM
Ws6power1's Avatar
So I understand they would be better because I could use different gaskets etc. Buy keeping the same boost would I actually gain or loose horsepower?
Old 03-18-2012, 08:17 PM
Adam86's Avatar
Same boost with a compression drop would cause a loss of power.
Old 03-18-2012, 08:44 PM
Ws6power1's Avatar
Yeah but wouldn't the better flow and better combustion chambers probably make up for the compression drop and keep horsepower about the same?
Old 03-18-2012, 09:40 PM
Nitroused383's Avatar
I think it would be a wash at the same boost. The gain would come from being able to safely run more boost on pump gas without detonation. The 317's may flow more but they do not have a very efficient combustion chamber. If you never plan on upping the boost than honestly it's not worth the hassle or cost.
Old 03-18-2012, 10:28 PM
Ws6power1's Avatar
Well I do have the motor pretty much stripped down where the swap would be really easy. Might be worth it just to run the better head gaskets for safety.
Old 03-19-2012, 12:38 AM
Ws6power1's Avatar
One more question. If I do the heads do I have to change pushrods? Or would it be a good idea to go ahead and do pushrods?
Old 03-19-2012, 03:26 AM
While at it install some good push rods and valve springs if you're going to swap. Usually guys with head gasket issues are pushing 1000 + hp on a forged motor.
Old 03-19-2012, 03:34 AM
My1st4thgen's Avatar
I would think you would benefit from the 317's you could run a pound or two more boost safely and have more power and way more reliability which i think is the biggest benefit. Also a good set of aftermarket pushrods are probably the way to go stock one don't like higher rpm's that much.
Old 03-19-2012, 04:50 AM
Ws6power1's Avatar
Ok so it sounds like I should do the pushrods. Do I just by stock lenght pushrods for the swap? I plan on getting new arp head bolts and I see there are 2 different kits. One for 98 -03 and one for 04-06. Which do I get? My car is a 98 but I'm not sure what year the heads are?
Old 03-19-2012, 07:26 AM
smokinHawk's Avatar
should be the same length pushrods as long as the head isnt milled.
Old 03-19-2012, 08:43 AM
Ws6power1's Avatar
What is stock length? I just wanna make sure I get the right ones.
Old 03-19-2012, 08:44 AM
Adam86's Avatar
7.400"
Quick Reply: How much would I gain from 317's?
