boost referenced regulator in the trunk ?
right now am collecting parts for a twin turbo setup.
the question is can I run boost referenced regulator in the trunk ? with a hard line from the engine for the pressure signal ? will it add any lag to the fuel delivery ? I want the unneeded fuel to circulate near the fuel tank .
Once the system is pressurized I don't know why it would make an appreciable difference.
FWIW I'm running my regulator back by the rear end and don't anticipate any issues. I know of another RX-7 that runs the same setup with no ill-effects.
