Pt76gts, run an oil restrictor?
I had a TC78 on my car(LY6) and never smoked or used any oil. Replaced it with a new PT7675, which I think is the same as a 76gts, and with no changes it smoked like a chimney and pushed oil into the compressor and turbine. I put smaller and smaller restrictors on it until it stopped, it still smokes around 100 degrees on cold mornings but stops by 130 degrees (engine temps)
Precision and a few dealers told me to not run a restrictor and send the turbo back to Precision, Im just running it as is and hoping it doesn't fail from lack of oil. I have a little over 1000 miles on it so far. I was afraid if I sent it back they'd keep it for a month or two and then tell me I did something wrong and charge me a bunch of money to rebuild it and have the same problem.
I had to clock my drain to about 30 degree angle to get a straighter shot to the pan. I tried it first pointing straight down and my line had to level out before it hit the pan. Basically the same kit you have. You need to make sure your line is always going slightly downhill. I wouldn't ever run a restricto in a journal bearing turbo.
Also what do you guys do to vent crankcase pressure?
im venting crankcase to atmosphere and running a 4an line no restricter i think 10an drain.. no problems at all. I think oil problems could be a combination of high crankcase pressure and a bad drain angle?
I run this setup for my PCV setup
