Holset HX55
I have had a Holset HX55 for a while now, getting ready to install. I finally opened it up and measured the wheels. Figure I would post what I found, since it seems to be a frequently asked question.
Exhaust
inducer = 80mm
exducer= 70mm
Compressor
inducer= 68mm
exducer= 100mm
not sure if that is the direct AR measurements or how all that works, but thought I would share the size.
Exhaust
inducer = 80mm
exducer= 70mm
Compressor
inducer= 68mm
exducer= 100mm
I think you might have measured that wrong. Each wheel has the inducer and exducer diameters. The compressor wheel's inducer side is the small diameter, the exducer is the large diameter. The turbine wheel's inducer is the large diameter, the exducer s the small diameter.
I know for a fact that the hx55 is not an 80mm turbo.
I like it. I dont have any experience running any other turbo on an LS but it does everything I need it to. Full boost at 3000rpm, I can be cruising on the freeway 6th gear and at 2k rpm full boost. Im only running 7psi on fully stock engine and at 525 rwhp. Still running strong over 2 years later. Plus the $200 cost makes it my kind of purchase. No need for big dollar turbos in my book. Plus this thing has massive room to grow. Diesel guys run these turbos up to huge PSI's
[IMG]https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/80-0126160
935_18e8a4cdfd98c3095d6149f997e924dc00efff01.jp
That's awesome!! I got heads and a cam in mine but the bottom is stock,,,im hoping for at least 600 whp..we'll see,,,,that thing is heavy! Did you have to make a Lot of braces for that thing?
You should have no problem getting 600. It is a big heavy turbo, and I did make a pretty serious mount for mine. It's hard mounted to the frame on mine but that was mostly because of the location I had to put it. I have some flex tubing going into it and the waste gate, no problems. No matter where you put it I would definitely fab some supports, kind of goes for all turbos in my mind, just not smart running them straight on the header if they have any decent size to them anyway.
Hey thanks for the info sorry it took me a bit to reply! I didn't get much info when I bought this turbo I know it's a 66mm, do you know roughly what cfm these Flo? Can't seem to find much about this particular one thanks a Lot.
Some more good info here on holset stuff. Ran a hx35 on my 1.8 Acura and made great power. http://www.realhomemadeturbo.com/for...ic,6181.0.html
Usually turbos are called out by the compressor inducer (smaller) ID, which is 68mm in your first post.
A on-line calculator I found suggests max power of about 725 (assuming everything else fits).
