LS9 cam not good with turbos???
Old 08-11-2012, 02:32 PM
  #41
Stangkilr's Avatar
I put down 860hp on 14lbs of boost with this cam in a stock LQ9 with LS3 heads (91mm turbo). Id say it works great!
Old 08-14-2012, 09:37 AM
  #42
1sick-Z's Avatar
Here is an idle clip of my Huron Speed turbo kit. LSA heads/LS9 cam on 2 bar SD tune. The idle is 880-900 and runs great. Nothing goofy going on at all.
Old 08-14-2012, 11:51 AM
  #43
Moderator
denmah's Avatar
i love me some ls9 cams, done three builds with them so far.
Old 10-18-2012, 03:58 PM
  #44
asb2106's Avatar
hey guys, sorry to pull this thread back but I had a question in regards to this ls9 cam..
1sickZ you said you recommend upgrading springs after 11 #s, what did you upgrade to?
Im looking for a set of springs with a minimum of ~ .6 lift probably dual spring..
But my question, if/when i do this, will the stock rocker from my 799 heads be the right ratio? I'm finding that 1.7 is the right rocker to use with this setup, and Im not able to find what ratio the 799 rockers use.?!
Thanks for any input
Old 10-18-2012, 10:57 PM
  #45
a4ls2goat's Avatar
I'm using the ls9 cam with lunati dual springs/comp push rods. Stock rockers on 799 heads.
Old 10-18-2012, 10:58 PM
  #46
Moderator
denmah's Avatar
PAC1218 springs are 140 dollars
and use all stock hardware, seals and keepers.
thats what i use
Old 10-19-2012, 12:01 AM
  #47
asb2106's Avatar
thats what i use
thanks .. I picked up set of PAC 1211X, a couple hours before u posted, paid bout the same and they are very similar.
Got the ls9 cam, front plate, already have a 1x gear on the motor, sensor, gaskets and seals. Heads should be here next week sometime (799's)
denmah, seen a few of your threads around a few boards and ..
Love reading your builds, i've learned a bunch.
stock rockers are 1.7 ratio... infact all are except ls7 (1.8). Picked up some literature and doing some reading. need to know this stuff
Old 10-19-2012, 12:25 AM
  #48
Moderator
denmah's Avatar
no need for reading, just apply boost to junk till it breaks and avoid that the next time hahah
Old 10-20-2012, 11:04 AM
  #49
3rdgentug's Avatar
HAHA thats sig worty
Old 11-22-2012, 02:34 PM
  #50
pmgm's Avatar
thats what i use
Hello, I'm going to run the ls9 cam in my 5.3 , I wanted to know where I can get the springs from?
Thanks
Old 11-22-2012, 07:28 PM
  #51
Louis's Avatar
Ls7 cam is identical, just a different lsa. LObe lift on the cam is the same, the ls7 lift appears higher because of the 1.8 rocker
Old 05-30-2015, 04:33 PM
  #52
08 pimpala ss's Avatar
Hey guys I'm doing this cam in my 07 impala SS can anyone verify if I need to use the 3 bolt conversion gear and any other input would be awesome also what push rods my motor is a 5.3 ls4
Old 05-31-2015, 08:34 AM
  #53
HRHohio's Avatar
Info:
http://lingenfelter.com/mm5/merchant...1#.VWsNZNJVhBc
"The LS9 camshaft is a 3 bolt design and will use the Lingenfelter 3 bolt cam conversion kit if you are installing it in a single bolt application like the 2007 – 2010 LS2 or LS3. If you are installing it in an earlier LS1 or LS6 engine with the cam sensor at the back of the engine you will need a 2005 LS2 front cover, 2005 1x cam sprocket, camshaft extension harness, 2005 LS2 chain dampner."
Old 07-07-2015, 03:01 PM
  #54
JJMclure's Avatar
Just to clarify, you only need to replace the front cover if you need the cam signal? If you are using Megasquirt 2 and only using the crank sensor you can just swap the cam?
Old 07-07-2015, 06:17 PM
  #55
stevieturbo's Avatar
I would always encourage you to run sequential if the ecu allows it, it will help if you're using larger injectors.
But if you do not need a cam signal because you're using a TDC referenced crank trigger like 60-2 or 36-1 etc, then any front timing cover will do.
That said LPE etc sell front timing cover kits with the cam sensor for very little money
http://www.lingenfelter.com/mm5/merc...E#.VZxchflViko
Then just use a 1x or whatever cam wheel suits you best.
Or Summit seems even cheaper
http://www.summitracing.com/int/part...3906/overview/
Old 11-02-2015, 11:00 PM
  #56
NemeSS's Avatar
Bump for newbs.
Been getting asked bout this cam in 4.8/5.3 budget turbo builds. Works awesome.
Old 01-27-2016, 10:05 AM
  #57
Brandon Ritchie's Avatar
Originally Posted by NemeSS
Bump for newbs.
I'm new to the ls game as well as so many others lol my main question is, with running a ls9 cam in my 5.3 lm7 what are the specs for the cam bearings? Can factory lm7 spec cam bearings be ran!
Old 01-27-2016, 08:20 PM
  #58
Turbo D's Avatar
Yes all factory LS's use the same cam bearings
Old 01-29-2016, 02:31 PM
  #59
Speed Freek's Avatar
Same ID, some earlier vs. later models have a slightly different OD. but I believe there are only 2 different variations of Cam bearing sizes for all LS platforms (not sure about LSX, I think they are different than OE)
However all cams will fit due to the same ID of the bearings.
So nice that so many parts are interchangeable with these LS motors...
Old 01-29-2016, 09:01 PM
  #60
gtfoxy's Avatar
Since this thread has some miles on it here is an article by Super Chevy that ran the LS9 vs a bigger LJS Stage 2. That way we can get another example of how it performs in a specific turbo application. For a $100-130 cam, I'd say it performed quite admirably.
One thing that has me curious is the difference in positive manifold pressure from one to the other. I surmise this is because the gate controller only looks at preset duty cycles rather than actual manifold pressure... I never used a turbo smart controller so I am not sure.
http://www.superchevy.com/how-to/eng...ged-ls-engine/
Quick Reply: LS9 cam not good with turbos???
