My 444 CI F1x C6Z build
Really looking forward to this! My new combo involves a F1X as well so I'm really interested to see how you get this sorted out. I think your going to need more injector though lol. My base will be a 427ci, F1X (Sprag as well), E-85 and I'm thinking I'm going to go a little higer on the static and see how she does. Following this on for sure!
I wanted to do a air to water intercooler system for this build so there would be no restrictions and better efficiency. I don't have the equipment or the fabrication skills that were needed for this project so I had a Local Saint Louis area welder/fabricator, Matt from HTP, take it on. His fabrication is top notch, and welds are like a machine's.
Inlet and outlet ports for the ice/water tank
Inside the tank has a mesh welded in to keep ice chunks from getting in the suction side and pump
this is my heat exchanger
the guts of the intercooler
#36
Thanks guys. There has been progress, but no major updates as of yet. There is a lot of work to be done still, but it is getting close.
I am running House of Boost's Aeromotive drop in Eliminator fuel pump with -8 Feed and -6 return, and running Injector Dynamics ID1000 Fuel injectors. It's a really nice, clean system that has been working well on a few cars that I've done locally.
#39
I will PM you guys his info.
