PCV Check Valves
Old 10-09-2012, 01:53 PM
Ferocity02's Avatar
Default PCV Check Valves
Where are you guys getting your PCV check valves? I found these on eBay. Mine would ideally have 3/8" hose barbs since that's the size of the PCV line I will be using.
Old 10-09-2012, 02:07 PM
JankesGTO's Avatar
gm pn 20861501
Old 10-09-2012, 02:09 PM
Doobie52's Avatar
I got mine from Treadstone.
http://www.treadstoneperformance.com...um+Check+Valve
Old 10-09-2012, 02:42 PM
SSpeedracer's Avatar
McMaster Carr PN 7775K12 buna or 7775K52 vitron
http://www.mcmaster.com/#standard-check-valves/=jndc08
Add a couple nylon 1/4 NPT to 3/8 hose barb fittings
I've had very good success with these as they crack open easy, completely seal when closed, and orifice is a good size slow the flow.
Old 10-09-2012, 03:18 PM
willizm's Avatar
bought mine from here.
http://www.boombaracing.com/cv.html
Old 10-09-2012, 05:08 PM
Build-it-Break-it's Avatar
[QUOTE=SSpeedracer;16796334]McMaster Carr PN 7775K12 buna or 7775K52 vitron
X2^^
Old 10-10-2012, 10:37 AM
Strokinit383's Avatar
I used this one from Grainger:
http://www.grainger.com/Grainger/SMC...ck-Valve-4DJA6
Old 10-18-2012, 11:01 PM
Ferocity02's Avatar
Will the 1/8 version flow enough? It just needs to flow more than the PCV valve. I already have some 1/8 NPT to 3/8 hose barb fittings.
Old 10-20-2012, 12:06 PM
Ferocity02's Avatar
Anyone?
Old 10-20-2012, 11:03 PM
LS1NOVA's Avatar
Originally Posted by JankesGTO
gm pn 20861501
This.
Doesnt get any easier. They were a recall part so every dealer will have them.
Quick Reply: PCV Check Valves
