BOV help needed. Turbo ls1
Old 10-14-2012, 04:21 AM
80gus's Avatar
Default BOV help needed. Turbo ls1
I'm nearing the finish of my engine conversion, I'm told by my tuner i need to put on a BOV as its a manual,
Where do i put it, pre cooler, after cooler, in the cooler??
And whats a good brand, Are the Tial valves worth the extra$$$$$
is 50mm a good size.
where do i put it
1 just after the turbo,
2 just before the TB
3 or from the the cooler
Old 10-14-2012, 07:46 AM
12 Second Truck Club
Bluchevypick's Avatar
The BOV can go anywhere in the cold pipes. Wherever you feel you want it. I plan on running Turbosmarts 50mm on mine. I would definately do a 50mm though just to be safe.
Old 10-14-2012, 10:02 AM
AutomagicLS1's Avatar
buy one of the 50mm race parts solutions bov's. I have 2 of them and both work great. Mine are right after the turbo
Old 10-14-2012, 10:13 AM
CALL911's Avatar
Prochargers big red BOV seems to be most popular, but its expensive. I opted for a 50mm Tial. Just bought mine new for $227 (almost half as much as ATI's BOV).
I would go with something that is known though, and not an ebay brand. The super cheap ones seem great until they break on you and you end up spending the money again in the end on something good.
Old 10-15-2012, 03:54 AM
80gus's Avatar
Thanks for the replies, I think I will get the Tial unit. as parts might be easier to get.
Old 10-16-2012, 08:43 PM
ACCLR8N's Avatar
I went with the column of air momentum theory and mounted mine as close to the throttle body as possible. My "research" indicates it doesn't really make a practical difference though.
Old 10-16-2012, 08:48 PM
LS1Tech Sponsor
Superman09's Avatar
I would put it between the intercooler and the TB.
BTW, cool looking set-up, what is the application?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 10-16-2012, 09:28 PM
LT1RAY's Avatar
It's going in a rock crawler.
Choice #2.
Old 10-16-2012, 09:45 PM
67Firebird455's Avatar
Also vote for Choice #2.
Old 10-17-2012, 02:39 AM
80gus's Avatar
once again, thanks for your help i think ill put in the second choice too, Its going in high speed 4wd comp truck.
Quick Reply: BOV help needed. Turbo ls1
