Found a cheap bracket for forward manifolds
So I had a hell of a time finding a bracket that would allow me to run my power steering pump and alternator on the drivers side head. Seemed like everything I looked at would have been in the 400-600 dollar range. I found this bracket a couple weeks ago. Comes with belt and hardware. It fits perfectly with forward facing truck manifolds. For $160 its a nice product and fits well. Though I would share with everyone as I had a hell of a time finding something for my build.
http://www.speedwaymotors.com/F-Body...ket,35274.html
"If you want to get rid of your power steering and move the alternator up to the driver side head, this is the bracket for you. It allows you to retain your original F-body alternator, balancer, A/C bracket and compressor.
Includes a billet aluminum bracket, belt and hardware."
Seems like this bracket gets rid of power steering according to their description.
My apologies. Turningfast got it right. there is two brackets, one taht includes power steering and one that is alternator only. This bolted right up even with my fabricated valve covers. Alternator hangs to the side perfect. I have the bracket turningfast linked, the alternator only bracket puts the alternator in the same location just no provisions to bolt up power steering.
Probably this is the one he is talking about
http://www.speedwaymotors.com/F-Body...ket,42493.html
I don't have any issues with that with a 3.5'' dp. Could run 4'' if the k member had enough clearance. stock tensioner location on water pump is used. you could definitely use a lower tensioner to get more clearance.
