How bad will the tourqer v 3 be with a turbo?
I was wondering if i was to buy a used tutbo kit how bad would my current set up be.
Motor has:
SLP Lid
Ported BBK manifold
85mm throttle body
UDP
BBK headers 1 3/4
Tourqer v3 cam kit
Ported oil pump
Double timing chain
Exhaust
Borla dual exhaust
Cut out after Y pipe
Bbk y pipe
Transmission:
Yank 4k stall
Trans cooler
Shift kit
Rear end:
3.73 motive gears. No whine at all
All mods very lows miles this is why I do not want to change. Also if it will work can someone point me in the right direction?
Motor has:
SLP Lid
Ported BBK manifold
85mm throttle body
UDP
BBK headers 1 3/4
Tourqer v3 cam kit
Ported oil pump
Double timing chain
Exhaust
Borla dual exhaust
Bbk y pipe
Transmission:
Yank 4k stall
Trans cooler
Shift kit
Rear end:
