Our Shop Car 427/88mm setup
We started this about a year ago working on it on saturdays. Car was my DD 10.5 second bracket car which had a C5R 427, A4 setup.
We stripped the car of all wiring,fuel,brakes ect. Here is what we put in
10 point from a local -Halls custom
427ci resleeved LS2 from Virginia Speed 9.5-1 comp.
TFS 235 6 bolt heads with inconel valves from TEA
Cam speced by us 236 intake
Morel link bar lifters
Stock GM LS7 gasket copper sprayed
Super victor intake with Aaron 90mm elbow
Madman motor plate
Alky control dual nozzle meth kit
Forced Induction GT47/55 -88mm
E-bay 4" intercooler which we made end tanks and welded on 3.5
" V-bands
3.5" cold air pipes
2- Tial blow offs
Custom hotside built by us with truck manifolds, 2.5" pipes, Tial 60mm wastegate, 5" downpipe necked to 4" exhaust under the car, 3.5" cutout out the front fender
Fuel is a Nasty fuel tank with Magnafuel 2035(forget model)fuel pump, -10 fead,-8 return,magnafuel regulator
127lb injector connection extended tip injectors
RPM level??? T400 with transbrake
Yank converter
Driveshaft shop carbon driveshaft
Midwest 9" with 35 spline axles,strange aluminum center,spool, 3.00 gears
AFCO shocks
Brakes are strange dual caliper rear,manual master.
Thats most of it. Will add more as I remember.
Pics coming up
Madman motor plate
" V-bands
3.5" cold air pipes
2- Tial blow offs
Yank converter
AFCO shocks
Pics coming up
I'll take some better engine bay pics soon.
Here is the dyno sheet of 9psi on reg 93 octain compared to 19psi 93octain/methenol. Got alot more tuning to do on the whole boost range but the tires were balling up on us causing the tires to spin. We have a few months before the track opens.
Yeah that looks nice. What material is that driveshaft? Is it carbon fiber or aluminum with a woven cover? Also, did a driveshaft let go at one point in the cars life? Just noticed the floor pans looked a little hammered.
The block is 4 bolt. Tea just gave us 6 boot heads incase.
Floor has been hammered for clearances ect.
It's a carbon shaft.
Car is built for some fun track time and cruise nights. We have no doubt it will go under 8.5's first day out. Next step is if we are going to upgrade the cage.
Wheels are billet specialties. Nice and cheap but seam strong.
Altinator was junk laying around the shop. Just hasn't been top priority to replace yet.
We still need to hardline all the vacuum lines,polish the aluminum,ty up wiring ect. Big thing was to lay into the motor/driveline and make sure it's all good which it is.
