FrozenBoost??
Mine are the Type 4: http://www.siliconeintakes.com/produ...1446c097fdc35a
I have seen people make 750hp with one, I figure 2 should be good for 1000. My air temps are a little higher then i would like. I'm going to change the pump and go back to the dyno in a few weeks.
We have used the 2000hp air to water and it held 1700hp no problem. We have another one here on the shelf. Some of the stuff they sell is cheap but we haven't had any problems with the big coolers.
Vega Jim...
Problem with the frozen boost cores is the size of the line they do the bungs for. Its not big enough. You arent getting enough water flow through the core. Especially if you are using a Rule pump.
Change the line out to 1inch to 1.5 inch depending on what pump you have and theyll work better...
You also picked out thier single pass cores.... the double pass core setups work a little better.
Vega Jim...
