Cam choice Turbo LQ9
I have a 04 silverado with a stock 6.0 in it, it has a 4l80 with a circle d converter. The truck has a T4 s472 with a 1.25a/r on it at the moment, with 12-15lbs of boost. I still tow with the truck. I have been looking and think I have narrowed it down to 2 cams, either the TU1 which is 225/225 .581" on a 113 or the Tick Stage 1 turbo cam 226/226 .60x on 114+3lsa. I thought about getting a custom cam however I will be changing the set up significantly if it blows or over next winter and will go that route then. I know people have had good luck with the tu1 but I have not heard much on the shelf grind tick cams.
