What to expect from a BONE STOCK lm7 or l33 turbo on pumpgas only?
Old 01-15-2013, 10:06 PM
boosteds10's Avatar
Default What to expect from a BONE STOCK lm7 or l33 turbo on pumpgas only?
As the title says, what could I expect from a bone stock (except for injectors) Unopened 5.3 with an on3 76 and a decent fmic on straight pump 93 no meth? With be going through a 4l80 and an 8.8 worth 3.08 gears.
Old 01-15-2013, 10:20 PM
TX RED's Avatar
Valve Float... Stick some Decent springs in there I'm pretty sure you'll break the 500hp mark
Old 01-15-2013, 10:26 PM
boosteds10's Avatar
Ok springs only. I'm hoping at least 500rwhp. I know it would be easier with the l33 but they are harder to find than the run of the mill lm7.
Old 01-16-2013, 05:58 PM
chiaj144's Avatar
I did 504rwhp at 8.6lbs of boost with a little mp70. Cam and spring l33.
Old 01-16-2013, 06:16 PM
boosteds10's Avatar
What cam and springs did you have? And through what trans and stall if it was an auto?
Old 01-17-2013, 05:56 AM
Moderator
03sierraslt's Avatar
Put good springs in it and small cam and let it eat. With good fuel and a good tune it will easily handle 500 plus quite a bit more.
Quick Reply: What to expect from a BONE STOCK lm7 or l33 turbo on pumpgas only?
