Need cam advice, Ls7 cam in 5.3 turbo? Specs inside
Okay here are the stock LS7 specs,
211/230@50
591/591 lift
120lsa
I can get a few of these for very cheap like under $100 so what u guys think in a lm7 with ported heads, 2in intake valves and s475 at 20 pisi boost?
211/230@50
591/591 lift
120lsa
Id say if you can get it cheap enough run it. I went thru the ls6 vs ls7 vs ls9 vs high priced custom debate myself. Im actually using the ls9 cam in my build. The ls9 is so close to a linginfelter cam they stopped producing it and used the ls9. Quite a few threads here on the subject. They all make power just depends on what you want to spend
