Killed the 5.3.... pics/video inside..
well after chasing a fueling issue ( had a failing fuel pump that didnt seem to show any symptoms that i could tell, just replaced pumps and the lean issue went away)
When the afrs were good i decided to turn up the boost since this is just a toy
ONLY MADE 3 RUNS at 12PSI
I guess the piston already had some damage because i left the wideband in the pickup to watch the afrs and it was spot on.... the pictures will show what i found when i tore it down tonight....
Judging by how clean and cylinder/piston/head were #7 im afraid i may have an injector problem on that cylider, intake leak, Head lifted and water in that cylinder, something.....??????????
What does everyone think? Possibly another issue??? Just afraid to put it together just to have it happen again lol
more specs on setup:
stock short 5.3
Siemens 60#
Dual in-tank walbro
227/231 614 617 112
PRC duals
4l80e
vig 3600
11.5 AFR only 12* max timing
I am in the process of throwing a piston/rod out of another 5.3 i have in the garage. along with new head gaskets, arp head bolts, arp rod bolts, and new lifters....
alot cleaner than other cylinders....
OUCH!!!!!!
Thanks in advance for your ideas and thoughts!
Just has me confused since i ran 14psi on my last motor for a LONG time with no issues.....
91 Octane fuel...... working on getting a water/meth kit also befor i beat on the motor to hard again (even tho0ugh last motor lived at 14psi on 91 only for a long time)
Ya there was detonation lol...
See im thinking something fishy also because of how clean that cylinder is..... just not sure what it is...
is it running really lean on that cylinder causing it to be so clean? my afr read 11.3-11.5 WOT all through boost, wich is plenty of fuel (look at rest of cylinders).....
if water was getting into that cylinder would it "wash" it cleaner like that?
it was right at .014 .... what do you guys think i should gap them to on the rest of the pistons since im here anyway? .025???
Going to check rest of ring gaps, throw new piston/rod in, new head gaskets, arp rod bolts, arp head bolts.... Then I'll throw new plugs in, make a run and check them very close....
Yes dual Springs
