Killed the 5.3.... pics/video inside..
Old Jan 18, 2013 | 02:54 PM
1BADLS1tuner's Avatar
Originally Posted by Haddixj
so whats the proper ring gap? for stock piston and rings?
I'm not an expert but i think I'm going to gap all to .025...... I remember reading somewhere there is a formula for figuring , something about bore size per spacing
Old Jan 18, 2013 | 03:05 PM
9sectruck's Avatar
my personal 5.3 is gapped at 24 top and bottom
.0055 per bore on boost/nos and .006 race app.
Old Jan 18, 2013 | 08:08 PM
So i just noticed my 5.3 has stronger rods than my donor 5.3.... So I'm going to swap piston from donor onto my rod....
Also noticed donor 5.3 piston has a cross on it and my 5.3 does not....... Assuming basically the same piston right?
Old Jan 18, 2013 | 08:47 PM
LilJayV10's Avatar
Originally Posted by c0ncEpT
If an injector stuck completely closed you would just end up with a hole that wouldn't fire. You need some kind of fuel for the motor to be lean. Its called air/fuel ratio for a reason.
Thanks for the reply *******. I see your point. I should have worded my reply better.
Old Jan 18, 2013 | 08:54 PM
That makes me Laugh ..... I needed that
Well i just switched the rods and pistons so now i gotta gap all rings and throw it back together and beat the hell out of it...
I also picked up everything to put meth on..... That should make it allot more
Old Jan 18, 2013 | 08:57 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by denmah
when iw ould check the stock motors there would be some with like 15 gap and other cyls with 22+ on a stock motor
This and E85 is the very reason some ppl get away with **** others don't.
Old Jan 18, 2013 | 09:15 PM
I wish i had E85 around here, but im in westen nebraska so there isnt much here for selection... 91 is the best i can get here....
Old Jan 18, 2013 | 09:57 PM
LilJayV10's Avatar
LOL. OK.
What kind of rings are you going with? Sorry if I missed it.
Old Jan 18, 2013 | 11:17 PM
LOL. OK.
Just the stock rings that were in there.... i just gapped the top rings to 25 and installed ARP rod bolts and called it good.
Tommorow ill get it put back together and go beat on it! Ill let you guys know the outcome!
