whats a good 3 bar map sensor?
Old 01-30-2013, 01:40 PM
tt383lt1's Avatar
Default whats a good 3 bar map sensor?
i need to buy a 3 bar map sensor for my lt1 and im wondering who makes a good sensor. i found some msd ones for $60 but i have no idea if there good.
Old 01-30-2013, 03:29 PM
Moderator
denmah's Avatar
http://www.ebay.com/itm/GM-style-3-b...item1c2e9fa7f3
i use these on all my builds
Old 01-30-2013, 03:37 PM
9sectruck's Avatar
^^^ same here
Old 01-30-2013, 03:45 PM
tt383lt1's Avatar
sweet thank you. i didnt know if it was something you get what you pay for. but thanks
Old 01-30-2013, 04:04 PM
LS1Tech Sponsor
hellbents10's Avatar
Wow that is cheap, I am used to 70 plus pigtail connector hahaha.
Old 01-30-2013, 04:34 PM
V-seriesTech's Avatar
http://www.racepartsolutions.com/pro...d=JOD-72225-10
Old 01-30-2013, 04:37 PM
Sumter's Avatar
I'm using this one
http://www.ebay.com/itm/16040749-3BA...d4ed4d&vxp=mtr
Old 01-30-2013, 04:44 PM
tt383lt1's Avatar
Originally Posted by Sumter
how long have you had it for?
Old 01-30-2013, 04:47 PM
Sumter's Avatar
I haven't driven the car much yet with it but it was doing fine on 18-19psi
Old 01-30-2013, 04:50 PM
Jontall's Avatar
People are starting to use the 3 Bar ZR1 Map sensor.
ZR1 map part # 12592525
Map sensor linear: 312.50 kpa
Map sensor offset: -11.25 kpa
http://www.hptuners.com/forum/showthread.php?t=35075
http://www.camaro5.com/forums//showthread.php?t=181803
Old 01-30-2013, 05:14 PM
stevieturbo's Avatar
That link does state GM style though. SO it is a cheap copy. Not a genuine GM sensor.
Old 01-30-2013, 06:17 PM
Moderator
denmah's Avatar
they are all GM style because of the connector, there are other map sensors, like just the element itself, or honda style etc.
just because it says GM style does not mean it isnt a chinese map sensor sunk into a 1 dollar piece of plastic like the rest of them. they all cost 1 dollar to produce
Old 02-03-2013, 04:08 PM
tt383lt1's Avatar
how much boost can a 3 bar handle? i know 2 bar is 29 psi. but i had a 3 bar on mine and on the dyno last time the 3 bar map took a **** and we couldnt get a 3 bar so we got a 2 bar and i went to 24 psi on a 2 bar and idk what the tuner did to achive this but the car runs fine and the a/f is good. this is also on e85 if that matters
Old 02-03-2013, 04:24 PM
allout06's Avatar
technically a 2-bar is good for 14.7psi, a 3 bar would be 29.4psi. Although people have gone higher.
Old 02-03-2013, 04:55 PM
GM 3 bar sensor reads up to 310kpa.
Of course you can tune beyond this if you wish. But it leaves no room for error if something goes wrong, and leave no option for an overboost cut.
It's little different to people continuing to tune with a maxed out MAF. You can do it, but things will be compromise, especially safety
Old 02-04-2013, 12:29 AM
runsfromdacops's Avatar
I use a omni "gm 3 bar style" map sensor. Its the old school brick style. But it works great and it was 1/3rd the price of the newer style oem ones
Old 02-04-2013, 09:23 AM
Chicago TDP's Avatar
What about the MAP off of a 2008+ Duramax?
I know my truck runs upper 30 PSI of boost...looking at the sensor it appears the same plug as the stock LSX Map.
Anyone want to try it out and see if it is plug and play for 3 bar???
Old 02-04-2013, 09:38 AM
7 Second Club
NicD's Avatar
All of those older block style 3 bar map sensors and the diesel 3.3 bar ones have terrible resolution down low and really only go down to 40 kpa which means decel and cruise areas will be muddy. A variance of a whopping 8% accuracy is about all you can expect at the higher and lower regions of the pressure range as well. At least the newer ZR1 map sensor is a lot better in those areas but putting negative numbers in the LS1 computers doesn't work either for the offset so it would be slightly skewed anyways but at least it's an accurate sensor.
Old 02-04-2013, 10:57 AM
So which is the best 3 bar sensor then?
Old 02-04-2013, 03:58 PM
Diesels would never operate under 100kpa, so may not even read vacuum.
Best is relative. The basic GM 3 bar is well tried and tested
Quick Reply: whats a good 3 bar map sensor?
