denmah's commonly bought turbo car items (update 7-11-16)
#322
Turbo Wastegate 50mm Type GT 14 PSI 1 Bar Red Nissan Toyota Mazda Acura Subaru | eBay
ive been using these for nearly everything lately, working great
No instructions came with it and I am lost.
thanks,
david
p.s. a pic would be great.
#323
According to AEM's instructions...They show a line coming off the turbo and tee'd to the side of the wastegate and to the solenoid. The other end of the solenoid goes to the top of the wastegate.
Do I have to drill and tap my turbo?
Or can I feed vacuum off the intake manifold?
thanks,
david
thanks,
david
#326
I'm using the AEM tru boost controller.
#328
Denmah,
I ordered a X02 Racing 60mm WG from VS racing for a side project. When you have used these in the past did they come with a very stiff spring in them? On my JGS gates I can hold them in my hand and push the valve with my thumb pretty easy ... I can't move the X02 one at all. Also do you modify the WG in any way before using?
thanks.
thanks.
#329
i just make sure that valve guide is low enough for the valve to seat against its seat tight, sometimes not often, the valve would have a gap, when you clamp both sides together...
so i would put a socket on the valve guide and hammer it down so the valve face would seal up nice..
but like i said rarely would that happen on the 50 dollar gates lol
make sure the stem has no burr's on it,
also the springs are usually super tight, usually comes with like 4 springs, 2 of wich are isntalled in the gate usually.
there is usually 2 larger springs and 2 small short ones
the largest spring, super weak you can collapse by hand usually 3psi ish
the next one 6ish?
both together 10-12
depends on backpressure and placement but thats how it goes
the next one 6ish?
both together 10-12
#330
On the turbo as AEM shows in their instructions?
Or anywhere on the intake manifold?
#333
the next one 6ish?
both together 10-12
the next one 6ish?
both together 10-12
#335
3 things I didn't see anyone really touch on when talking budget builds. For reference the cam in looking at is 228/228, .571/.571, 112LSA. I probably won't spin it higher than 6500rpm if not less.
-stock timing chain
-stock pushrods
-stock needle bearings (trunion upgrade?)
I'm building a backup budget 2006 lq4 (might swap into a different car) and piecing together things to keep the overall price down. These are the three things I'm on the fence about. Looking for 700whp through an auto
-stock timing chain
-stock pushrods
#337
Following up on the Stock 4L80e Torque Converter...
Denmah... I know you've had pretty good success with running the CirdleD converters, but I was wondering... have you had any issues with reliability in running the stock converter? I realize that there are benefits to running an aftermarket one (great points below), but for a budget builder who already has a 4L80e with stock TC, have there been any issues running it? Say up to 650 rwhp... ???
Thanks all!
Thanks all!
A stall or aftermarket converter does several things.
It can be build single or multiple disk depending on power levels
Can be stalled for almost any rpm range
can be ordered with different bolt patters to match the flex pate your using.
By stalling up the motor you will make boost at lower speeds and can be stalled to create boost from a stop. Also it keeps the engine with in the rpms of the power/torque curve.
#339
Bumpity?
(Or anyone else had experience running the stock 4L80E converter in the 650-700 rwhp range? ) Thnx!
Thanks all!
Thanks all!
