External oil pump for turbo system
Maybe its been done before idk.. I was thinking of mounting a external electric oil pump to feed the turbo. Just like have the turbo on a dry sump system... Im about to start my turbo build in a few month...
If its high enough, gravity drain it, no reason not too, unless you are doing something trick.
If you are going low/rear use the best pump on the market, Turbowerx EXA and never worry about it.
i did this on my V1 of my rear mount setup.
a work or advise is make sure you use a oil filter in the system as not having one can and will cost you a turbo as me how i know. also a oil cooler isnt a bad idea.
you will also need to bypass some of the oil after the pump but before the turbo to help take some of the load off the pump.
feel free to pm me im happy to help you out any way i can
-alex
-alex
I commend being different, and things of that nature,i really do, but if your putting the turbo up front, why? It really is going to add a lot of un-needed potential problems. I can see rear mount, maybe. But front mount, the oil is right their, drains back on its own, etc.
What if the pump fails? Do you own an accusump deal? The one that will prime your motor before you start it?
I think this is a valid thought. I have been thinking of the same thing on my dragster. My thought is turbos, in performance applications, are not filtered the best (or at all). the engine is bound to last longer than the turbo. If the turbo ran in its on oil, when it started to get shaft play ( bearing wear), the contaminates will not be in your cam, main, and rod bearings. I am not saying I am right, but it makes some sense.
what about using a power steering pump setup? or is that totally stupid?
