walbro 400lph fuel pump.
You would have to upgrade the bulkhead, racetronix has all the parts pretty cheap.
http://www.racetronix.biz/itemdesc.a...WH-017&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...WH-029&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...CS-028&eq=&Tp=
http://racetronix.com/press-release/...ing-harnesses/
In addition to the parts from Racetronix, ideally you should convert to a return system with an aftermarket regulator mounted near the rails
As stated before you'll need the GT280 bulkhead (and wiring) and a proplerly designed return system. The 3 parts linked above are offered by Racetronix in a single kit that's less expensive than buying everything individually. The pump isolator will need the bottom 1.5" cut off. You can retain the jet pump system by modifying the pump.
Not quite...refer to the following page for everything you need from Racetronix (chart near the bottom)
Is this still do-able with just the Walbro 400 in tank pump and the Racetronix hotwire kit?
I decided to go with a return system because it gives you the option to boost reference your fuel pressure
#32
I know people who have done it with success but Racetronix says it will overpower your stock regulator. This could lead to premature pump failure and/or issues at idle.
#33
Why not? Those are the same parts I listed.
#35
I am going to run one of the E85 pumps (450lph?) on gasoline with the aeromotive pump controller so its not running all out while cruising. Should be more than enough for my LM7/S400 build.
http://www.jegs.com/i/Aeromotive/027/16306/10002/-1
#37
#38
No different than the 255 that everybody modifies, INCLUDING Racetronix. Racetronix uses a threaded fitting, but the factory presses the fitting in, so why not do the same? Carefully cut the small brass barb out of the stock pump. DO NOT pry or pull on it. Drill a 11/64" hole in the top of the Walbro pump, opposite of the pump outlet, symmetrical to the pressure relief port - make sure no plastic drops into the pump. You only need to drill about 1/8" deep to breach the plastic. Press the brass barb into the hole - I used a 1/8" deep well socket. I have a few pics that I can post later.
Pump? Nobody said anything about including a pump. You can purchase the bulkhead, vapor connector, and hotwire harness as a single kit: http://www.racetronix.biz/customkiti...?kc=FPWK-017WX
I just looked at what I bought and forgot about the filter, tube, clamps, etc. Here's the entire list:
http://www.racetronix.biz/itemdesc.a...000267&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...FT-125&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...CLMP12%2E3&Tp=
http://www.racetronix.biz/itemdesc.a...13%2E3&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...S-250G&eq=&Tp=
#39
No different than the 255 that Racetronix modifies. Racetronix uses a threaded fitting, but the factory presses the fitting in, so why not do the same? Carefully cut the small brass barb out of the stock pump. DO NOT pry or pull on it. Drill a 11/64" hole in the top of the Walbro pump, opposite of the pump outlet, symmetrical to the pressure relief port - make sure no plastic drops into the pump. You only need to drill about 1/8" deep to breach the plastic. Press the brass barb into the hole - I used a 1/8" deep well socket. I have a few pics that I can post later.
