walbro 400lph fuel pump.
Old Mar 4, 2013 | 09:16 AM
geoguy1369's Avatar
Default walbro 400lph fuel pump.
Has anyone here tried walbro 400lph??? And what type of limit would 2 running parrallel. These pumps are getting cheap but are designed for intank use.
Old Mar 4, 2013 | 09:40 AM
denmah's Avatar
Moderator
i have two of them in my tank on my silverado they draw a serious amount of current
Old Mar 4, 2013 | 05:42 PM
Toxic-Evo's Avatar
WHAT. a serious amount of current???
At 4bar it is around 16 amps. that isnt much. they sell 100 amp relays. and getting a 40 amp fuse is easy. lol.
http://www.radiumauto.com/blog-page....l-Pump-Test-73 (i know this sint a sponsor. but this is a GREAT 3 party comparison)
Old Mar 4, 2013 | 05:58 PM
turbocamaro125's Avatar
they have walbro e85 pumps and walbro 400 gas pumps...make sure you check it out
Old Mar 4, 2013 | 07:30 PM
denmah's Avatar
Moderator
well i have done dual pumps in tanks before and never had in tanks that required this much amperage.
thats all.
Old Mar 4, 2013 | 08:11 PM
geoguy1369's Avatar
I plan on 2 in my bird but was just wondering if anyone else is using them. At 120 a piece you cant beat it
Old Mar 4, 2013 | 08:42 PM
tta656's Avatar
So a single Walbro 400 is good for 1029 HP in turbo applications...damnnn you only need one...2 is over kill
Old Mar 4, 2013 | 10:33 PM
badhombre's Avatar
Steve your not going to use those 255's? get 2 of the 340's intank. small, little current draw and very quiet. I love mine
 Michael S. Palmer
denmah's Avatar
Moderator
well, i could not get solid numbers at the time, and cant believe everything on the internet.
other flow tests rate them at 800crank, others say 800 wheel, like mentioned, 120 a piece is cheap...
figured if i ever put in a built motor and a 91mm turbo i would never have to touch the pumps and tank again.
oh well.
Old Mar 4, 2013 | 10:36 PM
badhombre's Avatar
BTW guys he is planning to run e85 so fuel system will have to be slightly overbuilt as compared to pump gas
Old Mar 4, 2013 | 10:38 PM
denmah's Avatar
Moderator
be careful there are gasoline 400s and e85 400s
foose04 ran the gasoline 400s with e85 and they burned out in a year or less
Old Mar 5, 2013 | 01:06 AM
Danny's Avatar
You can use the E85 models for both E85 and gas right?
Old Mar 5, 2013 | 02:01 AM
Gonoma's Avatar
Where are these being found for 120 each? Or is that for the gasoline model?
Old Mar 5, 2013 | 07:10 AM
geoguy1369's Avatar
I'm actually planning pump I think and maybe some meth. Ebay has them for that. The stealth pumps are nice but I'm not wanting to spent that much. E85 would be every once in awhile.
Old Mar 5, 2013 | 10:11 AM
denmah's Avatar
Moderator
i got them for 120 a piece with the install kit on ebay
http://www.ebay.com/itm/170920168201...84.m1497.l2649
Old Mar 6, 2013 | 02:45 AM
narfdanarf's Avatar
The only difference between the gas and e85 version is the sealed connector for the pump which makes it ethanol compatible and a couple bucks extra.
Old Mar 6, 2013 | 10:48 AM
Danny's Avatar
These look bigger than the Aeromotive 340s or the similar Walbros, will 2 Walbro 400s fit in a factory Fbody tank? If so than maybe these are what I need to feed 1300HP worth of E85.
Old Mar 6, 2013 | 03:41 PM
M&M Turbochargers's Avatar
the 400 walbro's seem worth considering
Old Mar 7, 2013 | 12:03 PM
67Firebird455's Avatar
That is so cheap. I love it. Have a friend running one in his e85 talon and loves it.
Old Mar 7, 2013 | 01:45 PM
Forcefed86's Avatar
The ethanol version is good for 700+ whp at 7300 rpm on a 4.8 LS. 10 feed, -8 return.
The E85 units are shorter, have a different PN, and claim to flow 450lph? Either way 700+ on e85 through 1 pump is impressive.
https://ls1tech.com/forums/forced-in...8-146-a-2.html
