TT selection and vender plz!
Old 03-04-2013, 10:47 AM
spaulsen's Avatar
Default TT selection and vender plz!
Im doing a tt precision turbo build in my 98 camaro. Looking for around 1100rwhp. I want to know what intercooler you guys have used and if there any venders here that sell a great intercooler. thx, Shawn
Old 03-04-2013, 05:36 PM
Toxic-Evo's Avatar
Tread stone has best bang for buck for a 1300 horse cooler
Old 03-04-2013, 10:09 PM
spaulsen's Avatar
any venders here sell treadstone?
Old 03-05-2013, 05:06 AM
Anchor's Avatar
I went with twin Turbonetics 72mm Mid Frame BB turbos. And the treadstone dual inlet, single outlet over the radiator intercooler. My goal is 1100rwhp with 398ci and T56.
Old 03-05-2013, 07:24 AM
spaulsen's Avatar
Do you remember the part number? Did u purchase it from a vendor on here?
Old 03-05-2013, 08:56 AM
garrysturbo's Avatar
Trttc9
Old 03-05-2013, 07:48 PM
dregg100's Avatar
you can make that kinda power with much smaller, faster spooling turbo's.
Old 03-05-2013, 07:59 PM
LilJohn's Avatar
At what cost to reliability?
Smaller turbo means you have to push the pressure ratio and shaft rpm higher to get the desired mass flow. Most shaft rpm means more heat. On an air to air equipped car thats not a good thing.
Your assometer couldnt tell the spool difference in a pair of 66's versus a pair of 72's no matter how much you may try and make me believe you can.
Oversize the compressor a touch...reduce required shaft rpm to make X hp and reduce the heat made getting there. Its the smart way of doing it.
And the Treadstone end tank design is garbage. Inlet is too close to the core. The tank is too skinny. Buy the proper sized bare garrett core and have someone fabricate better end tanks.
Old 03-06-2013, 03:03 AM
Anchor's Avatar
Exactly why I went bigger turbos than I needed. And it was no extra cost for me to do so.
As for the intercooler, I only went the treadstone based on price vs reviews. The bigger turbos will lower the heat that the intercooler can't cool. Good enough for now.
I can't comment on how it all works yet though...
Old 03-06-2013, 09:21 AM
runsfromdacops's Avatar
over sizing turbos is a waste.
you will lose spool time and gain no power for it.more lag and the same power? that sounds fun to drive.
for your combo id go with twin PTE billet 6262s no bigger.
i have PTE5858s on my car (a little smaller motor) and i think they still have more to give, 1k rwhp atlest
Old 03-06-2013, 09:41 AM
Reject's Avatar
so to mix **** up, thought about running an a/w ic?
Old 03-06-2013, 10:52 AM
LilJohn's Avatar
If you were so worried about spool response.... you wouldnt have done a rear mount.
Old 03-06-2013, 10:57 AM
if i had the room that the fbody guys have under the hood i would have done front mounts. but this car has less room under the hood then a honda civic so i did what i had to.
never the less over sizing the turbos hurts spool time with no benefit to anything, front or rear mounted.
Old 03-06-2013, 11:07 AM
Reject's Avatar
stick it next to the block like all the other platforms do lol
Old 03-06-2013, 09:59 PM
LS1NOVA's Avatar
The Treadstone unit mentioned above does perform very well though. Friend is putting 1000whp though one. Intake air temps gain around 10-15 degrees from ambient on a pull.
Old 03-08-2013, 07:32 AM
spaulsen's Avatar
I have thought about a a2w. Id really like to go that route but idk which to use, or which one fits the best. Any suggestions?
Old 03-08-2013, 09:20 PM
Anchor's Avatar
Is that around normal?
Old 03-08-2013, 09:46 PM
Z06_Fan's Avatar
On a dyno pull? 1/4 mile pull ? mile ?
Old 03-08-2013, 10:50 PM
LilJohn's Avatar
And just imagine what it would do if the end tank design wasnt crap and the whole core was utilized not just about 60-70% of it.
Quick Reply: TT selection and vender plz!
