Aps tt short block predicament
At a bit of a crossroad here with a short block build.
Bought the car and put maybe twenty miles on it before it put a couple of rods through the side of the block. Was diagnosing crank sensor signal loss/backfire when it occured with a new sensor. Not sure if it was the cause but all rods were bent with no detonation marks on pistons or plugs.
Anyways,
I'm looking to build a new short block but ran into a few issues.
Here are my options for a budget build.
Goal is 600ish to the wheels. It did 555 at 8psi when a previous owner had it - stock bottom 317s and a small cam.
We only have 94 octane e10 here... no e85. I also cant seem to find a bare lq4 block up here in Canada or else I would just build that.
1. I have a 1999 4.8/5.3 block. I want to bore it out to 3.898 to avoid hurting resale. Forged piston/rods stock crank. The problem with this is no one has an ultrasonic tester to check wall thickness within 400KM from me. Do I just punch it out and forget about it?
2. Use the above mentioned block and build a forged 5.3 - Seems like this would be plenty strong but I am worried it would hurt resale do to the smaller motor.
3. Use the above block, put in 05+ 5.3 rods/pistons, open ring gaps. (cheapest option)
4. Run a stock lq4. I can get these for $1000 complete. But none over 2005. They have 1 04 motor.so its gamble if it has the newer rods or not.
5. Run a stock ly6. $1000 for these but need ls3 intake and 58x conversion box. I wonder how much more hp this motor would produce due to the l92 heads.
Thanks for the input.
Anyways,
#2 The 5.3L is plenty of cubic inches to make big power. Even GM uses the 5.3L on the highest hp COPO Camaro, with a 4.0L blower. That gives you forged rods and pistons, for about what option #4 costs with stock parts.
http://www.chevroletperformance.com/...opo-camaro.jsp
I'm doing a 4.8 ls with my APS/LGM I'm installing soon. I't has a short stroke and small bore. But there are more then a few people on this board and on youtube using small ls motors making a lot of power.... 800 to 998 rwhp...
I'm using a stock bottom end and stock 243 heads.
looking to make a lot of power with this set up.
