How to prevent meth spraying on 2-step?
M6 d1sc with meth on hobbs switch. Im worried that if I set a two-step at Let's say 5000rpm it will be spraying meth while on the two-step. What's my solution? Is there a way to cut power to meth pump when clutch pedal is pressed? Thanks for any input.
not sure what 2-step you are using, but I have a harlan 2 step from years ago that has an ouput wire so that you can wire up a nitrous system to come on as soon as the 2-step input is released
Rich AFR might cause it to be sluggish off the line. I'm sure you can find ways around it being sluggish off the line, but I would think wiring an interrupt relay would be best for the methanol pump.
Nitrous guys use an interuppt relay to interrupt their nitrous solenoid relay so it doesn't spray on the trans brake.
If the AFR was optimal with the methanol spraying I see nothing wrong with it spraying. I used to spray methanol on the two step on my old car with no issues, but I did foul out all my plugs and o2 sensors once from setting the activation too low and the AFR got too rich.
Yep that's what needs to happen I just am unsure how to do it. Anyone wire up a two step and meth pump this way?
anyone want to walk me threw this? I think I understand this but I wouldnt mind someone holding my hand lol Im a plumber not really into "wiring"
