holley 12-1800 fuel pumps for FI
Old 06-20-2013, 04:48 PM
Detoxx03's Avatar
I know A&A uses them for their twin pump fuel kit. http://www.aacorvette.com/supercharg...roducts_id=435
Lots of guys with blowers making north of 750 use them with great success.
Old 03-05-2014, 06:06 PM
BLWN1's Avatar
Thinking about this route..
Old 03-05-2014, 06:27 PM
SMOKNSS's Avatar
I have only seen one set of these in person and they are in a TT 5.3 Mustang. The owner told me they have performed flawlessly. I'm assuming around 600ish rhwp.
I talked to the owner of Hinson Motorsports the last time I was there and he also told me that they have used these pumps and have not had any issues in the cars they have installed them in and said that they should be fine for around a grand at the wheels on the corn.
I can't decide if I am going to give these a try or not.... I guess I will have to see after some more people use them.
Old 03-06-2014, 01:26 AM
ittwgn's Avatar
here's a couple pics run 2 of the 12-1800hp pumps with surge tank!! cheers
Old 03-06-2014, 03:24 AM
408RAT's Avatar
Wow, how much hp are you running to need two!?
Old 03-06-2014, 06:39 AM
Sarg's Avatar
So are they now rated to be run with e85? On the chart it just shows gas and diesel.
Old 03-06-2014, 07:52 AM
stevieturbo's Avatar
Dont forget, that when used at normal EFI pressures even on normal petrol, the 1800hp claims fall well short.
More like half of that.
I guess running 4 pumps like that can make sense. They are a neat package, and when all are running it is overkill. So at least even if one fails, you still have an excess of fuel.
Old 03-06-2014, 10:38 AM
dmaxvaz's Avatar
what's the reason for the surge tank? is any of the pumps on a hobbs switch?
Old 03-06-2014, 12:43 PM
Man-Crush Warning
Shownomercy's Avatar
Easier and cheaper to have a pump fill a surge tank at low pressure and then have high pressure pump(s) kick on pulling from surge tank when under boost.
Old 03-06-2014, 01:02 PM
Correct.
Main reason though is it eliminates any surge problems with having a large main tank, and fuel potentially sloshing away from the pickup
And saves any mucking about modifying the main tank.
It seems less common in the US, as you mostly drag guys just seem to sump the tanks as fuel only goes rearwards.
But an external swirl, surge, whatever you want to call it is a pretty easy and versatile way of building a solid fuel system
Old 03-06-2014, 01:47 PM
408RAT's Avatar
Was kinda hoping one of these would be enough to support 800whp using 127lb injectors e85
Old 03-06-2014, 01:59 PM
  #32
MustangLS's Avatar
You should be fine. I'm running the 12-800 with 120lb injectors, 45psi base pressure and E85 without any issues. I haven't had it on the dyno but at 14psi, 3250 race weight I've been 9.44 @ 142 (mid 700RWHP based on most calculators). I've had it up to 23.5psi for a brief moment and didn't show any signs of fuel starvation.
Old 03-06-2014, 03:44 PM
  #33
dmaxvaz's Avatar
my setup made 801 rwhp with this pump/FIC 1000s/e85/17psi boost @ 90% dc
Old 03-06-2014, 08:31 PM
  #34
408RAT's Avatar
Awesome, thanks guys.
Old 03-06-2014, 09:28 PM
  #35
LT1PWRD's Avatar
Just curious,anyone take theirs apart yet? The body looks like a good size housing for a couple of 340lph in tankers.
Old 03-07-2014, 12:43 AM
  #36
ittwgn's Avatar
reason for surge tank has been answered by others!! I actually maxed out 2 of the walbro e85 450lph pumps @ 24psi and 1148rwhp and rapidly rising hence the reason to go 2 dominators and a new tank !! should go 1200ish on pump e85 will know soon yes its setup on 1 pump and at 6ish psi kick in the other 3 !!! street strip wagon !!! cheers
Old 03-07-2014, 03:14 AM
  #37
More than likely that is what is inside the housing.
Old 03-07-2014, 04:40 AM
  #38
samdogmx's Avatar
you'll be fine at that level. I run 120s on E85 too.
Old 09-14-2014, 01:55 PM
  #39
6togo's Avatar
Bringing this back up anyone in the 1K+ hp range with these pumps and how they holding up?
Old 09-14-2014, 08:43 PM
  #40
ls1curt's Avatar
Just had a pump fail in my 12-1400.
Quick Reply: holley 12-1800 fuel pumps for FI
