what heads to run with my maggie
Old 04-29-2013, 01:35 PM
s10_ls1's Avatar
Default what heads to run with my maggie
like the title says im looking for a set of heads to run on my stock bore ls1 with the magnacharger i have a set of afr 230cc mongoose heads with 65cc chambers i figure i need the 72cc chambers to help with the compression i figure the 65cc chambers where alittle much but any suggestions would be great on head selection...the motor is a stoke bore ls1 with the maggie, brian tooley stg3 positive displacment cam and alittle spray any help would be great thanks guys
Old 04-29-2013, 02:34 PM
Brian Tooley Racing's Avatar
TEA has the TFS 220 As Cast "LS2" heads with an optional 70cc chamber that would work. You'd have a little bit of bore overhang, but no more than you have now.
Some powdered metal guides so you can run stock rockers and my Platinum spring kit would have you all set!
Old 04-29-2013, 05:21 PM
s10_ls1's Avatar
thanks brian for all the help still havent called you back and ordered the cam the deal on the magna charger fell through and now i have bought another one so i will be calling ya in the next day or two and ordering that
Old 05-12-2013, 05:16 PM
s10_ls1's Avatar
anyone else??
Old 05-12-2013, 07:14 PM
MonmouthCtyLS7's Avatar
From the research ive done Maggie's like compression....
Quick Reply: what heads to run with my maggie
