s 10 w 5.3 p1sc procharger
Old 06-10-2013, 06:31 PM
turby57's Avatar
Smile s 10 w 5.3 p1sc procharger
Going to stuff a 5.3 and turbo 350 in 91 s10 tonight after work. I was wondering if the stock manifolds will work. Picked up a tci flywheel spacer today, next thing I have to figure out is how to mount the procharger. I got a emailed copy of install manual for a 5.3 from procharger today, so that will help with location, and belt, intercooler. This is gona be fun!!!
Old 06-10-2013, 09:11 PM
Tuckin15s's Avatar
Stock 5.3 truck mani's will not work you will have to track down some f-body manis and just recommending but i would weld some v bands on them to eliminate a pain in the *** install. On another note really looking forward to the procharger install on a s10 I have been tossing around the Idea of a procharger for some time.
Old 06-10-2013, 09:13 PM
jgb454ss's Avatar
In for results
Old 06-10-2013, 09:24 PM
LS1Tech Sponsor
hellbents10's Avatar
I will ask Chad to post his S10 blazer pics on here. He had a 2003 2 door 2wd with a non ic E85 and p1. Went 12.0@122-3 if I remember right on 8-9psi.
Old 06-10-2013, 11:06 PM
turby57's Avatar
Thanks guys for the input, I need as much help as possible with this, first time i have ever messed with a supercharger. I had a s 10 with a 355 before but it wouldn't hook. This one has a narrowed 12 bolt and a 390 posi, with a built 350 turbo trans. I also need to find out what is involved with the carb needing to be a blow through????? Thanks again for the help! Chad will post pics if I can figure out how
Old 06-10-2013, 11:23 PM
turby57's Avatar
Old 06-11-2013, 04:17 PM
turby57's Avatar
I found a set of shorty camaro headers today for 100.00 do you think they would work
Quick Reply: s 10 w 5.3 p1sc procharger
