5.3 block machined to a.....????
Old Jun 9, 2013 | 10:50 PM
01transampower's Avatar
Default 5.3 block machined to a.....????
Well to make a long story short I tried doing a 5.3 build for my 2001 T/A. Well with the amount of rust in the cylinders its been decided to have the block machined. The biggest I was told that block can be taken to is 383? Also what do you guys then would be ideal between stock and there?
I am using a 76mm turbo with a full fuel system and everything to make this scream. It is not a drag car just going to be a fast street car with occasional track time a mostly street driven.
Would it be ideal to go in the middle for save cylinder wall clearance? Such as a 364 or 370?
Old Jun 9, 2013 | 11:59 PM
yelo04goat's Avatar
Common would be 3.903-3.905 bore for 5.7 or 347 ci. And you can use the crank you got still
Old Jun 10, 2013 | 12:53 AM
Johnv's Avatar
The difference between a 347 ci and 383 ci is the crank (4" stroke) bore is the same.
Old Jun 10, 2013 | 06:33 AM
1fast bird's Avatar
The issue with 5.3's is there aren't too many off the shelf pistons for them. This is why people are boring them to 3.905" (347" w/ stock stroke or 383' with a 4" stroke). Plenty of choices when you go all the way out to ls1 size bore....but on the other hand this is eliminating the point of having a 5.3 IMO, that is the thicker cylinder walls.
Old Jun 10, 2013 | 08:43 AM
got-a-ls1's Avatar
weisco has 3.80's so you can bore it .020
Old Jun 10, 2013 | 11:02 AM
1fast bird's Avatar
Yes that is the only one I can think of. May not be the desired compression with that particular piston though.
Old Jun 10, 2013 | 11:25 AM
RonSSNova's Avatar
Wiseco has 2 basic choices in the JY series. High compression and low compression for use with the stock rods.
Or, use an aftermarket rod with a a piston that falls in between.
Here is their info:
Note that compression ratio is based on a pretty small chamber size.
And, they do make a piston for a 4" stroke crank.
Ron
Old Jun 10, 2013 | 05:19 PM
Blackpanther99's Avatar
This^^
Old Jun 10, 2013 | 09:54 PM
JAX04's Avatar
Just got mine back, 5.3 to 3.905 bore.
Old Jun 11, 2013 | 06:33 AM
1fast bird's Avatar
Glad to see Wiseco is making more piston options now.
Old Jun 11, 2013 | 04:04 PM
So by making it a 347 in a sense what kind of power can be obtained with this? I want the best option for everything. I just know there are so many options out there for this.
Old Jun 11, 2013 | 04:23 PM
HRHohio's Avatar
Instead of putting the money towards machine work/pistons/rings/balancing/etc ($$$!) you could just get another 5.3 short block.
Get another short block and put the money you saved into heads and cam for the most benefit/dollar. As is, a 5.3 is good for up to 1000 rwhp with enough boost.
