Simple Hobbs switch question
I'm needing to wire in my Hobbs switch asap; however, I'm unsure which wire is positive and which is negative that lead into the switch. The Hobbs switch does a need a 12v source correct??
This is the switch I have:
http://www.lsxtune.com/shop/product_...roducts_id/576
This is the pig tail I have:
http://www.lsxtune.com/shop/product_...roducts_id/844
As you can see both wires on pigtail are black and I don't see any markings designating positive or negative on the switch.
I tried calling LSXtune for help, but the guy that deals with these switches is out of town.
Thanks.
Thanks.
both wires are the same. one is in, one is out. when the preset pressure is reached. it connects the circuit. like turning on a light switch. you connect the wires.
hope that explains it ok.
