Differences in Derale Fans
Does anyone have any pictures of the Derale puller fan 16926? Or could you tell me which way the blades curve?
I have two of the derale 16925 pushers on the front of the condenser, and it doesn't get enough air to the radiator. I think I can make enough room to put one on the back of the radiator. Looking at Derale's pictures it looks like the fan blades are identical. I wanted to verify swapping polarities would still flow good as a puller, before going through the hassle of changing everything around.
Called derale and the guy wasn't much help. At first he acted like they were the exact same fan, then said the blade design might be different cause the pictures are generic and the only way to know would be to try it.....
I'll let u know in five days. I just ordered a 16926 and a 16925, to use one both sides of my rad, obviously they will be offset from eachother! For my front mount set up.. I got two shitty 10" pullers right now and they are not enough at all.. So hopefully this will work good!
Hey gpr, I'm going to the post office to pick up the fans in a few hours, since I only use my phone for a computer it's hard to post pics. I'll Pm you my cell number and I can send u the pics via text message if you would like!?
