all you BW guys, what would you put on a 4.8?
He specifically said t6 turbo, going t4 would cause another $200
With that said I woukd run tye same s472/83 which is $650 althought if you want room to grow go with the s475/83 which is the same price! Spool difference wont be much different and if you ever want a quicker spool and more power you can always run a more turbo oriented camshaft.
Whoops. Didn't read that far. T6 is too big for that motor IMO. I have a 6.0 and wish I went T4.
S475 with a 83mm turbine and 1.10 A/R housing, if its a street car/truck. Foose04' s RCSB made over 900 rwhp with one last year with a 4.8, TU1 cam, truck manifold and E85 and it was very responsive.
Maybe DrTurbo will chime in. The 96mm turbine is a little on the big side for a street driven 4.8 but would work good at the track with a 2 step though.
Not sure but I think the 650 dollar unit has the 96mm turbine, it cost a little extra to get the different turbine and smaller A/R housing's.
http://forcedinductions.com/productsborgwarner.htm
Got mine from HS. There are two listed, one is 649 the ither is 699 same specs.
