Possible Spark blow out at 25psi w/LS1 coils
Old 09-16-2013, 08:12 PM
ttcamaro's Avatar
Default Possible Spark blow out at 25psi w/LS1 coils
Im running the BS3 on my supra with the LS1 coils. Last year i ran 30psi with a .028-.030 gap on the plugs with no issues. Changed over to a mechanical pump and 240lb injectors. Took the car out recently and it starts breaking up around 20psi. Thinking it was just plugs i pulled them put new in. Took the car out again same results. I was going to run more boost and bring the gap down but want to figure out what happen here. How can i check for a weak coil?
Old 09-16-2013, 09:03 PM
SPRAYED 01's Avatar
What rpm is it breaking up at? Could it nee valve float?
Old 09-16-2013, 09:38 PM
ttcamaro's Avatar
Doesn't seem to be rpm related first gear only makes about 12psi but winds out to 8500 just fine
Old 09-16-2013, 10:03 PM
corpserodeo666's Avatar
Go down to .025 that should probably help you out. Also what plug are you running?
Old 09-16-2013, 11:36 PM
Moderator
denmah's Avatar
too much gap, i slam right down to 22 gap for 20lbs with a tr6
Old 09-17-2013, 09:44 AM
LS1Tech Sponsor
hellbents10's Avatar
I think your new fuel system is working really good and you might need to pull some fuel too. I set the gap at .020 to start, and make sure you have enough dwell time at that rpm.
Old 09-17-2013, 09:49 AM
DEFYANT's Avatar
LS1Tech, we help Supra guys
Old 09-17-2013, 11:25 AM
elkydragger's Avatar
Maybe switch to truck coils, and step up to 16 volts on the common ignition feeds. Merely just a suggestion. I would listen to Hellbent first!
Old 09-17-2013, 08:24 PM
ttcamaro's Avatar
Thanks for the replies. What would u recommend for dwell time? After everything is working I plan on running upwards of 40psi. Thoughts on plug gap with 45psi?
Old 09-17-2013, 08:30 PM
green94z's Avatar
Springs, cam lobe too radical, had same issue, tried down to .016 no change
Old 09-17-2013, 09:54 PM
lazaris's Avatar
"Im running the BS3 on my supra with the LS1 coils. Last year i ran 30psi with a .028-.030 gap on the plugs with no issues."
"Changed over to a mechanical pump and 240lb injectors. Took the car out recently and it starts breaking up around 20psi."
I would look at the change you made and start there.
Old 09-18-2013, 12:50 PM
JAX04's Avatar
I would most def listen to this man! :
Quick Reply: Possible Spark blow out at 25psi w/LS1 coils
