Procharger BOV mounting HELP
Does it matter or make any performance difference if you mount the Procharger Big Red BOV with the standard length supplied piece of tube or a custom tube that has a 90* and is 18" long? I
Reason is, I don't have hardly any room to mount this thing.
Below is the tight spot that I could use the supplied mounting tube. The radiator is about 1/2" away from the side you can't see.
The pick below shows a spot with a little more room and I wanted to make a bracket to the blower bracket to help support it. Are there any problems with mounting it upside down also?
Thanks for the help
Allen
Thanks for the help
Allen
