changed WG spring, issues
Old Oct 3, 2013 | 07:40 PM
ToxicWS6's Avatar
Default changed WG spring, issues
so i had an 8psi waste gate spring in, and went to up to a 12psi spring, well i switched them out, i seem to have the same power as 8psi, my gauge says 12 but it sounds like it shudders, what i was wondering is do i need to change a bov valve spring too?? would that cause my BOV to flutter with higher boost?
Old Oct 3, 2013 | 09:28 PM
Twin turbo c5's Avatar
Are you just running on the spring or are you running a controller. I've had the same problem outta boost controllers. I wouldn't think the bov would flutter but I guess it is possible . What size wg ?
Old Oct 4, 2013 | 09:06 AM
ToxicWS6's Avatar
its just a new spring, no controller, and pretty sure 44mm, like the car dosnt lose power it just feels basically like i did on 8psi, just makes alot more turbo noise and a weird studdery sound.
im gunna try a diff tune and see what it does but ill look more into the BOV situation too, everything i read though said use the lightest spring possible
Old Oct 4, 2013 | 11:53 AM
Sarg's Avatar
Is it the wastegate or turbo making the noise? Could be compressor being upset with ya...
Old Oct 4, 2013 | 02:42 PM
ToxicWS6's Avatar
hard to tell cause its not real distinct, something else i thought of is race season ended so i closed my exhaust back up and its real restrictive, could this cause it to feel like its loosing boost up top?
Old Oct 4, 2013 | 04:01 PM
[QUOTE=ToxicWS6;17729593]hard to tell cause its not real distinct, something else i thought of is race season ended so i closed my exhaust back up and its real restrictive, could this cause it to feel like its loosing boost up top?[/QUO Yes defintly it could fall off up top . If exhaust is real restrictive it'll kill it for sure on a turbo application.
Old Oct 4, 2013 | 06:39 PM
ToxicWS6's Avatar
so i opened back up my cut out, i gained 2psi and alot more noise lol, still dosnt pull like it should and sounds the same
my question now is, can i breaking up cause of not enough fuel and still read rich?
Old Oct 4, 2013 | 06:47 PM
Johnv's Avatar
If it's breaking up, check your plug gaps, close them down to around 28 thou.
Also what valve springs are you running ? if std, your probably getting valve float at the higher boost level.
And check with a wideband that you have enough fuel in your tune for the extra boost, or you may kiss your engine goodbye .
Old Oct 4, 2013 | 07:45 PM
ToxicWS6's Avatar
wide band is between 10.8-11.4 mostly through the pull, ive thought a out the plug gapping, im running tr6s atm
Old Oct 5, 2013 | 01:23 AM
smokeshow's Avatar
Plugs or coil packs...
Old Oct 5, 2013 | 09:49 AM
ToxicWS6's Avatar
ight thanks guys! ill check them today and let u know what i find
Old Oct 5, 2013 | 01:45 PM
ToxicWS6's Avatar
it was plug gaps, had them at .44 for what ever reason, set them to .22 and now 2nd gears pretty scary! lol, thanks guys!
