My mustang street car I built this year...
Old 10-14-2013, 07:22 AM
  #41
skinnies's Avatar
Originally Posted by Stumped1215
How much boost are you leaving with? No trans brake correct?
Leaving on brake with 8lbs this last weekend.
Old 10-16-2013, 09:10 AM
  #42
cam
cam's Avatar
Inspiring little beast! Whats the rear suspension set up? I see coil overs, is it mini tubbed too? What kind of cage is in there? Fuel type?
Old 10-16-2013, 10:36 AM
  #43
skinnies's Avatar
Strange coilovers, unsure of lca/uca brand as it was on the car when I got it, same with ARB was on there when I bought the car. It has a split tub so not a true mini tub that was done by the previous owner. 8.50 chromoly cage and I run e98 cut down some(since all our pump e85 is only e70 here)
Old 10-16-2013, 10:44 AM
  #44
cam
cam's Avatar
Thanks, great combo. You put together nice packages with just the right bits. Ever consider running straight meth?
Old 10-16-2013, 01:26 PM
  #45
bad6as's Avatar
whats the specs on the bottom end?
Old 10-16-2013, 07:04 PM
  #46
JoeyGC5's Avatar
Gorgeous and HARD running car Justin
Old 10-17-2013, 06:09 AM
  #47
skinnies's Avatar
Nothing special, eagle crank/rods with wiseco pistons. Block isn't filled or o ringed or anything special.
I drive the car A LOT, only way I could go straight meth is if I did the dual fuel on it, even then not sure I want to go that far with it.
Old 10-17-2013, 07:40 AM
  #48
kjm
kjm's Avatar
what cam/rockers you running in that beast????
Old 10-17-2013, 09:20 AM
  #49
skinnies's Avatar
speed inc tu3 cam, stock rockers with trunion upgrade, stock lifters
Old 10-17-2013, 09:41 AM
  #50
Moderator
denmah's Avatar
incredible, is this still a stock engine?
Old 10-17-2013, 09:45 AM
  #51
kjm
kjm's Avatar
Thanks for the input.... sorry for all the questions
I just picked up a ly6 6.0 with the l92 heads and slapping the L76 intake on with twin 76mm so its fairly close to your setup that cam may be the direction I head in its a tube chassis all fiberglass 1957 so should be fairly light
Great work on all your cars I love dyno numbers but you always got the fast times to back it up
Old 10-17-2013, 09:47 AM
  #52
Moderator
denmah's Avatar
an i see pistons and rods
Old 10-17-2013, 10:12 AM
  #53
Rise of the Phoenix's Avatar
What AFR heads are you running?
Old 10-17-2013, 10:53 AM
  #54
skinnies's Avatar
Out of the box afr 225's.
Old 10-17-2013, 02:24 PM
  #55
cjmatt's Avatar
I love this build. Any details on the fuel setup? you must need a ton of flow for the e98. How does it idle with big injectors? any other pics of how you have the piping routed? im curious to see how you pipe twins in a mustang with the a2a
Old 10-17-2013, 05:37 PM
  #56
93camaro_zzz's Avatar
Awesome car man! Your combo just flat out works!
Old 10-17-2013, 06:11 PM
  #57
White.Lightning's Avatar
Sick car man. It rolls the F out!
Old 10-18-2013, 06:03 AM
  #58
skinnies's Avatar
3 bosch 044 pumps, 10an line, 220lb injectors. It idles great, you would never know it has a huge injector in it. Don't really have many pics of the building of it, the manifolds are facing forward under frame into turbo, downpipes go back through frame and exit in front of front tires below fender, coldside is just a 1000 crank hp rated treadstone intercooler going in each side at bottom and out the drivers side at top.
Old 10-18-2013, 06:29 AM
  #59
kjm
kjm's Avatar
What alternator bracket you running?
Old 10-18-2013, 07:10 AM
  #60
Ryans99ls1's Avatar
high or low impedance injectors?
Quick Reply: My mustang street car I built this year...
