Oil drains in a 5.3 twin turbo build. How do I weld in AN fittings
Old 10-27-2013, 08:58 PM
FIRECHICKEN5.3's Avatar
Default Oil drains in a 5.3 twin turbo build. How do I weld in AN fittings
So I just got the 5.3. I'm getting an LS1 pan for my thirdgen swap. I want to install the AN bulkhead drains in the pan. Do they make aluminum fittings to weld to aluminum? I have only seen the steel ones
Old 10-28-2013, 04:51 AM
samdogmx's Avatar
yes they make alum weld bungs
Old 10-28-2013, 05:37 AM
yenkomike's Avatar
I had the timing cover off of mine and there is a good spot on the pass side of the balancer I just drilled it and got a 90*an to pipe thread fitting tapped it 3/8 npt and it works good.
Old 10-28-2013, 07:53 PM
Ok great. I'll look for a weld in aluminum bung to weld in the pan..
I need two drains for a twin turbo setup that's why I chose the pan
Old 10-29-2013, 07:44 AM
Photochop's Avatar
If the pans coming off you could drill it and use a bulkhead fitting and not have to worry about welding
Old 10-29-2013, 03:28 PM
allout06's Avatar
^thats what i did. -10an to 1/2" NPT adapter. used some thread sealant.
Old 10-29-2013, 08:09 PM
LT1RAY's Avatar
I used a -10 bung from Jegs and welded it on the inside.
Old 10-29-2013, 09:08 PM
Texhotrod593's Avatar
Looks pretty low but the weld looks good
Old 10-30-2013, 06:36 AM
allout06's Avatar
I put mine up in the slope of the oil pan.
Old 10-30-2013, 09:25 PM
A bulk head fitting is one that sandwiches the pan between the fitting right? Would it come loose or leak over time?
LT1Ray- I like the 90 degree fitting with the barbs. Any chance you have a part number handy?
Old 10-30-2013, 09:55 PM
allumini's Avatar
These have been used in the past.
http://www.jegs.com/i/JEGS-Performan...oductId=755321
Old 10-30-2013, 10:56 PM
allout06's Avatar
This is what I used
http://www.summitracing.com/parts/sum-220047b
Old 10-31-2013, 08:30 AM
LT1RAY's Avatar
My setup is as low on the pan as possible since my turbo is mounted low, works perfect. I used Jegs part number 555-110073 pushloc fittings and for the pan 800-8108. I used -10 pushloc hose from Jegs as well.
Quick Reply: Oil drains in a 5.3 twin turbo build. How do I weld in AN fittings
